Body Control Module - JeepForum.com
post #1 of 10 Old 10-09-2004, 02:54 PM Thread Starter
KeithH
Body Control Module
I have a 2001 Grand Cherokee Limited, V8, alltime 4WD, 35,000 miles. For the second time in 15 months the body control module has gone out (first time at 20,000 miles). My Jeep dealer here in Las Vegas is trying to tell me I am the only one having this problem. The BCM is not covered under the extended warranty which makes me suspicious as to the frequency of their going out however my dealer is covering the replacment under Chrysler's warranty due to the period of time since they replaced the last BCM.
Anyone else having this problem with the BCM? Anyone with any ideas as to why mine may be going out so quickly. the Jeep dealer doesn't offer any clues.
Thanks.
KeithH in Las Vegas.
KeithH is offline
post #2 of 10 Old 10-09-2004, 03:09 PM
Meerkat
I have had no problems with mine. It would help to know what kind of failure your BCM is suffering.
Here is a functional description of the BCM:
These vehicles use a body controller to control many of the body systems that previously used stand alone modules. There is only one "level" of Body Control Module (BCM) available as opposed to other vehicle lines that use a base or premium controller. To send and receive information the modules utilize the CCD bus currently used on other Chrysler vehicles. The bus is supplied bias or power from three different modules. The BCM and both the driver's door (DDM) and the passenger's door (PDM) modules can provide bus bias. Normally, the door modules only provide bias until their message has been sent, if the BCM is in a "sleep" mode. After the BCM "wakes up", it takes over biasing the bus.
Termination is provided from two modules, the Powertrain Control Module (PCM) and the BCM. As in other systems, termination is used to control the voltage level of the bus. Termination resistors used in the PCM and BCM typically measure 120 ohms of resistance each. Most bus systems use two points of termination for a back up in case of failure of one of the modules. If there are two points of termination, then total resistance of the bus circuit would equal approximately 60 ohms . This measurement could be made at the DLC after the bus becomes inactive.
The body control module provides or supports the following features:
Intermittent Wipe control
Door, Hood, Liftgate, Rear Glass Ajar Status
Reading and Transmitting of External Temperature
A/C Select Switch Status
Chime
Courtesy Lamps (including halo) with time-out feature
Automatic Headlamp Control
Headlamp Time Delay
Automatic Funeral Mode (with automatic headlamp only)
Gulf Coast Country Overspeed Warning
Illuminated Entry
Instrument Panel Dimming
Vehicle Theft Security System with Panic Mode
Door Lock Inhibit (key in ignition or headlamps/parklamps on)
Electronic Odometer Support
Brake Pressure/Park Brake Switch diagnostics
High Beam Indicator
Seatbelt Reminder
Speed Sensitive Intermittent Wiper Control
Fog Lamp Control
Remote Radio Controls and Radio Support
Mechanical Instrument Cluster Support
BCM Diagnostic Support
VIC (vehicle information center) support
Liftgate Courtesy Lamp Disable
Rear Window Defogger Control
The BCM receives information over the CCD Bus from the PCM in order to support certain features. The required information is as follows:
Engine RPM
Injector on Time and Distance Pulses
Vehicle Speed
Engine and Battery Temperature
Charging System Failure, Engine Temperature Limp-In, VTSS Arming Status
Engine Model
"Check Engine" lamp status
The BCM provides the PCM with information on the A/C switch status and the `OK to Start' or VTSS status.
The BCM has several programmable features. These features are enabled and disabled by using the DRB. See the chart.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 10 Old 10-10-2004, 12:37 AM Thread Starter
KeithH
Body control module failures
Warren
The body control module failure I experienced both times took out my A/C, info center, headlights, windows, wipers, moon roof. Dash lights, flashers, door locks, seats, brake lights all continued working.
KeithH
KeithH is offline
post #4 of 10 Old 10-10-2004, 06:53 AM
Meerkat
Keith,
Just the fact the failure took out the same components both times tells me that there is something external to the BCM that is damaging those circuits.
How long is the BCM lasting before it has to be replaced?
Here is a block diagram of the BCM system. Take a look at it and see if you can find any commonality in the failures. In other words, when I look at it, I think that all the components you said quit working are carried on the white 'B' connector. If a point external to the BCM that is common to only those functions that failed can be identified, then we will be able to establish the true problem that is burning up your BCMs.
HTH
Warren
Meerkat is offline
post #5 of 10 Old 10-10-2004, 10:19 PM Thread Starter
KeithH
Body Control Module
Warren,
25 months before replacing the 1st BCM and 16 months for the second. I will speak with my dealer more about the cause and effect Monday. Thanks for your input and diagram.
KeithH in Las Vegas
KeithH is offline
post #6 of 10 Old 12-01-2011, 04:17 PM
Green96
I am new to this so sorry if I an doing this wrong! What year is this diagram for? I have a96 that I think may have a bad bcm and ecm . Whats a shut down relay? And why the hell do jeeps have so many electrical issues? jeep dealerships should be notified!
Green96 is offline
post #7 of 10 Old 12-01-2011, 07:11 PM
KoreaZJ
1994 ZJ
AUTOMATIC SHUT DOWN (ASD) RELAY
When the ignition switch is in either the START or RUN position, it connects circuit A1 from fuse 8 in the Power Distribution Center (PDC) to circuit A21. Circuit A21 powers circuit F99 through PDC fuse 18. Circuit F99 feeds the coil side of the Automatic Shut Down (ASD) relay. The Powertrain Control Module (PCM) provides ground for the relay on circuit K900. Circuit K900 connects to cavity C3 of the PCM. When the PCM grounds the ASD relay, contacts inside the relay close and connect circuit F5 from fuse 20 in the PDC to circuit A142. Circuit A142 splices to the generator field terminal, fuel injectors, ignition coil and the upstream and downstream heated oxygen sensors. Circuit A142 also connects to cavity C12 of the PCM.
KoreaZJ is offline
post #8 of 10 Old 01-01-2012, 09:28 PM
Green96
Can an bad ignition switch cause stalling?
Green96 is offline
post #9 of 10 Old 01-28-2012, 01:34 PM
Green96
I put a new ecm in and no more stalling. Still reading p0420 code, cadilis effecency code also dont have gage or window power although sometime turning on headlights turns on window n gag power
Green96 is offline
post #10 of 10 Old 01-28-2012, 07:20 PM
samsonitesamson
holy thread resurrection batman.
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
Body Control Module CoyoteCruiser ZJ Grand Cherokee Forum 25 06-10-2016 05:32 PM
Body Contorl Module or Door Control Module?? Drdan524 ZJ Grand Cherokee Forum 4 05-19-2010 01:04 PM
Driver Door Module or Body Control Module ronmaynard ZJ Grand Cherokee Forum 3 04-28-2008 08:13 AM
body control module buzzbomb ZJ Grand Cherokee Forum 8 06-30-2004 07:00 AM
Body Control Module jane8888 ZJ Grand Cherokee Forum 0 06-25-2004 06:41 PM
