Body Contorl Module or Door Control Module?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Body Contorl Module or Door Control Module??
Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-05-2006, 05:09 AM   #1
Drdan524
I just purchased a 1996 ZJ with 4.0L. There are a lot of problems with it but I got it for the right price. Now the problem I am working on is with the body parts i.e. windows, security system, etc. The problem is the driver's side windows, locks, mirror works fine, but nothing works on the passenger side. I am getting power to the passenger side but no signals for the windows, locks or mirror. I do not have access to the Jeep scan tool (DRB) and I just don't want to throw darts and money at this problem. Any help would be greatly appreciated!!!!
Thanks
Dan
Drdan524 is offline   Reply With Quote
Unread 05-05-2006, 06:08 AM   #2
heydave
I would say that you have a broken wire in the doorjamb. I have read that you can disconnect the wire harness from the door and unplug from under the dash to remove for repair.
Dave
93 Grand Cherokee (wife claimed it)
94 Grand Cherokee (toy)
heydave is offline   Reply With Quote
Unread 05-05-2006, 08:27 PM   #3
CurtP
Not on the '96+ ZJ's - the harness that runs to the doors is part of the floor wiring harness. It could be unplugged and pulled back to do the repair, but it would have to be done in the vehicle. Pulling the entire wiring harness is pretty involved - the seats need to be pulled, the kickpanel trim, rear side panels and carpet have to come out too. Those rubber boots at the front doors are a PITA too - especially the passenger side.
If there is a broken wire in the door jamb, the proper way to repair it is to remove the section that is in the rubber boot and to have the solder joints near the plug and outside the boot. If it's fixed in the area where it repeatedly bends, it will fail again.
CurtP is offline   Reply With Quote
Unread 05-05-2006, 09:41 PM   #4
Meerkat
Broken wires for sure.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Unread 05-19-2010, 01:04 PM   #5
riley3d
Was it broken wires or a bad BCM? I have the same exact problem on a 97 ZJ Larendo, 4.0. Mine works 5% of the time. Off and on when you are driving. Cant find any bad wires. Mechanics have looked too. I am putting in a BCM as soon as I find a used one. I will let you know if that fixes it.
riley3d is offline   Reply With Quote
