On board water - JeepForum.com
post #1 of 13 Old 10-15-2013, 11:05 PM Thread Starter
riot1987
On board water
I want a water tank to put in the rear, near the wheel well im thinking. I want to be able to pressurize it and have running water. Any ideas where to begin looking for a tank?
Build thread^^
riot1987 is offline
post #2 of 13 Old 10-15-2013, 11:22 PM
WJ4x4LIFE
hot or cold water only or both? what is the use/s you in plan to use it for?
WJ4x4LIFE is offline
post #3 of 13 Old 10-15-2013, 11:25 PM Thread Starter
riot1987
Camping. I want about 5 gallons of water. I was thinking about hot... Coil a copper water around my exhaust headers..? Id be happy with just cold though if I could
Build thread^^
riot1987 is offline
post #4 of 13 Old 10-15-2013, 11:30 PM
WJ4x4LIFE
If you feel up to the challenge you could do something like this, I will start on this project to my NEW ZJ as soon as I pick it up on Thursday 10/17/13. I have another link to a COLD water only as well...got to find it. Saved the link for who knows how long....
HOT & COLD
http://offroadpassport.com/forum/showthread.php?t=754
post #5 of 13 Old 10-15-2013, 11:33 PM Thread Starter
riot1987
Eventually ill have an OBA setup so I was thinking If I had an air valve for my tank, I could pressurize the tank as needed and have running water
Input?
Build thread^^
riot1987 is offline
post #6 of 13 Old 10-15-2013, 11:41 PM
WJ4x4LIFE
Input?
that could work, better off with 2 tanks. I would start at RV world, they have steel 5-20 gallon tanks in all kinds of shapes and sizes. One tank with air and water would be nice, but I would make a wall in between. Then place 2 plugs on the water side to run a 12v pump to make life great.
http://www.jeepforum.com/forum/f310/...rmany-1460065/
thread post #3, half way down, this is an idea. I like this German's creative spaces....
post #7 of 13 Old 10-15-2013, 11:49 PM Thread Starter
riot1987
If I could get a high PSI rated tank for water Id be fine. I wont be running a tank for my OBA. It will essentially be on or off
Build thread^^
riot1987 is offline
post #8 of 13 Old 10-16-2013, 01:00 AM
kg6mov
Hears the voices
kg6mov's Avatar
We put these things in the bottom of set pieces all the time to have running water: http://www.northerntool.com/shop/too...FSiCQgodSBoA8A
If you don't mind pumping every once in a while it's not a bad simple solution.
kg6mov is offline
post #9 of 13 Old 10-16-2013, 01:05 AM
kg6mov
Hears the voices
kg6mov's Avatar
Actually this looks interesting, an onboard pump to keep the system pressurized: http://www.northerntool.com/shop/too...8864_200518864
kg6mov is offline
post #10 of 13 Old 10-16-2013, 07:59 AM Thread Starter
riot1987
Those may work actually.. Ideally, I was hoping for a more fitted shape to the tank though
Build thread^^
riot1987 is offline
post #11 of 13 Old 10-16-2013, 08:10 AM
WhiteOut
WhiteOut's Avatar
http://www.jeepforum.com/forum/f9/ob...build-1236148/
There is also a guy on the JK side who has a pressurized tank and a tap mounted.
WhiteOut is offline
post #12 of 13 Old 10-16-2013, 08:40 AM
PolkaPower
There is a WJ on Expedition Portal with on board water. He has a heat exchanger in the engine bay and a tap for the water on his front bumper. He uses a neat portable shower set up.
PolkaPower is offline
post #13 of 13 Old 10-16-2013, 10:25 AM
OverlandZJ
theksmith.. search his username and you'll find his WJ build.
I'd just opt for a shurflo 12v pump and a food grade water container if this will be for drinking water.
I'v been using a ZODI for heated water and a shower source in camp. The pump drops into a MWC easily, and the setup is portable if you need it away from the rig.. or used elsewhere.
OverlandZJ is offline
