on-board air in a WJ - JeepForum.com
post #1 of 13 Old 04-28-2005, 09:41 PM Thread Starter
FearTheDentist
Just a suggestion...
FearTheDentist's Avatar
Has anybody put an on-board air compressor in their WJ? If so, can you point me in the right direction?
Thanks!
'04 4.7 WJ 6" Clayton's, full width 60\14b, 37" Nitto mud grapplers, lots of bits and pieces
FearTheDentist is offline
post #2 of 13 Old 04-28-2005, 10:55 PM
scubatch2
what type, electric or motor driven?
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #3 of 13 Old 04-28-2005, 11:05 PM Thread Starter
FearTheDentist
motor driven
I'm looking for motor driven
post #4 of 13 Old 04-29-2005, 12:10 AM
Buddha_Kip
Buddha_Kip's Avatar
if you don't mind losing yoru air conditioning, you'd use your stock compressor. Since you're out in devil country, I doubt you'd want to go that route. Most popular way (motor driven) is to hijack a York compressor (any older (pre-93ish) Mercedes you'd come across has the correct one), but I don't know of anyone who makes the crossover brackets to use in the WJ.
You'd prolly be better off going electric & getting a Viair compressor (450 is a good model [1.62 cu.ft/min 100% duty cycle, and it won't break the bank) and a scuba tank and running that through. Would give you the best options on how you'd want it run.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #5 of 13 Old 04-29-2005, 12:26 AM Thread Starter
FearTheDentist
Viair compressor
Whats the difference between the 45 and the 500? The 500 has 50% greater CFM, but I don't know what 33% duty cycle vs. 100% duty cycle means...
My main goal is to be able to re-seat a bead if needed, and I'd like to be able to run air tools in a pinch (although a power inverter and electric really would work fine too...) I'd think that once you got past the install a motor driven system would be more capable and less hassle, but maybe this is overkill. Two weekends ago I slipped a bead and one of the guys had a motor driven system in his Jeep- I was REALLY impressed by it- had my bead re-seated and tire (over)inflated in like a minute. Maybe it's overkill for my needs but that's never stopped me before
I'll have to look if there's room for a compressor in my engine compartment- it's REALLY packed in there with a 4.7....If there is I can have brackets fabricated. I'll write it up if I do it.
post #6 of 13 Old 04-29-2005, 12:30 AM Thread Starter
FearTheDentist
Viair compressor
N\M the differences in the Viair compressors...they have a very good FAQ on their site....I'd still like to know how noisy they are tho..
post #7 of 13 Old 04-29-2005, 03:07 PM
cajunmudder
cajunmudder's Avatar
They are pretty loud, if its on the inside you will have to yell to talk. What I'm thinking of doing is getting a pancake tank and a Viair 450 to put in my spare tire well.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #8 of 13 Old 04-29-2005, 08:10 PM
Buddha_Kip
Buddha_Kip's Avatar
not super loud...not like an at-home/shop air compressor, but there is some noise, but then again, you'll only hear itfirst when it's airing up the tank, and then only when you go below the required psi....at which point you'll most probably be outside of the truck using your tools or airing up, so it shouldn't make much of a difference anyway.
post #9 of 13 Old 04-29-2005, 09:33 PM Thread Starter
FearTheDentist
Noise supression
OK- so I was thinking about how to keep the noise down (again, this is probably overkill)....How much heat do these produce? I was thinking of mounting it under the truck, in which case I'd want to put it in some kind of enclosure to protect it, or at least a skid plate of some sort. An enclosure is an attractive idea because I could add some insulation and really cut down on the noise (try it with your garage compressor- it really helps!) My worry with the enclosure would be generating too much heat. It wouldn't be a big deal to add in a 12v fan to help airflow, but I'm not sure that would be enough. Has anyone seen or done anything like this?
post #10 of 13 Old 04-30-2005, 12:17 PM
cajunmudder
Yeah Im more used to hearing them in cars with bags like a 62 chevy wagon where theres two viars under the back floor. Its loud as -=-=-=-=
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
post #11 of 13 Old 04-30-2005, 01:13 PM
CunningLinguist
the fastest 12v compressor around!
Run air tools continuously
The Review!
Just Empty Every Pocket!
02 WJ Limited V8, KRC Engine, RAM45 545RFE Trans, Clayton Long Arm.
03 WJ Laredo I6, IRO 4", 31x11.5 LTB
Originally Posted by Dope Schemes
By all means enjoy Halo 2.5 but for those with cerebral development beyond that of a spider monkey, pick up Bioshock, you won't regret it.
CunningLinguist is offline
post #12 of 13 Old 04-30-2005, 01:20 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The Review!
Did you mount that in your Jeep? If so where?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #13 of 13 Old 04-30-2005, 01:27 PM
CunningLinguist
this is the link to the production stuff. I have the XD series. It is mounted on the small off-road trailer I tow, Similar to the tenttrax trailers with the fold up tent.
Oasis Off Road Mfg Compressors
A/C as On board Air ? zjeepin ZJ Grand Cherokee Forum 8 10-14-2008 10:46 AM
On board Air nierace ZJ Grand Cherokee Forum 45 06-03-2007 01:28 PM
New to the board. scoop55 ZJ Grand Cherokee Forum 3 04-04-2006 10:43 AM
new to the board teasley ZJ Grand Cherokee Forum 12 10-21-2005 07:23 AM
On Board Air ZgreatJ ZJ Grand Cherokee Forum 1 05-02-2005 07:59 PM
