Blown Water Pump :( - JeepForum.com
post #1 of 10 Old 01-12-2004, 02:28 PM Thread Starter
GrandRubicon155
Blown Water Pump :(
i went to killington, VT last week and the temperature hit -19 and i think my coolant froze and caused my water pump to break. i woke up the next morning after the drive home to find that my 93' Grand was leaking coolant everywhere. could it be a busted hose? how can i tell for sure that it's the water pump? has anyone ever replaced one on their own? let me know what you think and how it went. thanks guys
sean
99' TJ Sport, 31inch MTR's, Lift Comming Soon
GrandRubicon155 is offline
post #2 of 10 Old 01-14-2004, 06:19 AM
Meerkat
sean
9 times out of 10 it will be your water pump. Hoses generally have enough flexability to expand around any ice without bursting. As far as replacing the water pump goes, it is not difficult, but is hard work. It's a good project.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 10 Old 01-14-2004, 08:42 PM
Silver yj
There is a spot on the bottom of the water pump that is called a wheep hole ( I think that is how its spelled ) It will leak out of there when the pump is bad,the only way to realy see it is with a miror.Also if the Antifreez froze then you better check around for soft plugs leaking also.
Silver yj is offline
post #4 of 10 Old 01-15-2004, 09:43 AM
deeger
deeger's Avatar
Water pump replacement
GrandRubicon155,
Just replaced a water pump on my '94 GC 5.2L V8. Mine started to leak which typically indicates the pump will totally crap the bed soon. If you know which end of a wrench to hold, you can do the pump replacement yourself in about an hour. With 150K miles on my Jeep, I did some preventive maintenance, replacing the lower radiator hose and the small 5" long hose that connects to the top of the pump.
Good luck.
Deeger
If it ain't broke...fiddle with it 'til it is
'94 ZJ Black 5.2 V8, AMRacing Wheels, BFGs, 160K miles
'95 BMW 525i stock
'97 Honda CBR900RR Erion Racing Edition
deeger is offline
post #5 of 10 Old 01-15-2004, 10:20 AM Thread Starter
GrandRubicon155
thanks for the help guys, i got everything taken care of and she's running pretty well for having 180,000 miles. hopefully nothing will break in the next 2-3 months so i can save some money for future mods. thanks again
sean
post #6 of 10 Old 01-15-2004, 11:06 AM
Jim Moore
Originally Posted by deeger
GrandRubicon155,
Good luck.
Deeger
Folks-
Hi. I just registered on the site. I just "inherited" a '96 Grand Cherokee with 142K miles from my wife because she bought a brand spankin' new 04 GC. Last weekend the water pump crapped out on me. I managed to get it changed, but it was a PITA. I wish I had found this site prior to doing the work. I have a quick question for those who have changed the water pump. How did you remove the big nut that holds the fan on the pulley? I ended up jamming a big screwdriver between the pulley and the water pump housing to hold the pulley still, but I assume there is a smarter / better way to do this?
Thanks in advance,
Jim Moore is offline
post #7 of 10 Old 01-15-2004, 11:42 AM
deeger
deeger's Avatar
JimMoore,
Water pump relacement on a 5.2L V8 is indeed a PITA. That frickin', son-of-a-biach nut you refer to on the fan assembly was a challenge. I tried your method of jamming a large screwdriver into the pump pully mechanism, but couldn't get the shaft to stop turning. After exhausting all other options, and running out of patience and swear words, GarageLogic finally engaged. I removed the water pump with the fan still attached. In the process, I knifed two hoses, convincing myself that they probably needed to be replaced anyway. With the pump and fan lose, I was able to extract the plastic radiator shroud...which by the way...I have since renamed "That Black Piece of Plastic from HELL".
On the workbench, with the pump locked in a vice, the big nut gave up the battle. Installation was simply backtracking the steps. 30 minutes later I lit up a victory cigar, and declared it to be Miller Time.
Total cost was under $100. (includes a few band-aids).
Deeger
'95 BMW 525i stock
deeger is offline
post #8 of 10 Old 01-15-2004, 12:05 PM
Jim Moore
JimMoore,
I removed the water pump with the fan still attached. Deeger
Good thinking. I was wondering if that whole assembly would squeeze out. I'll do it that way if I ever have to do the water pump again.
Jim Moore
San Diego, CA
'96 GCL
2004 GCL
post #9 of 10 Old 01-18-2004, 01:33 AM
94ZZJJ
JimMoore,
Deeger
Agreed!
I figured out that a strap wrench(rubber) will work. I used that and a 36mm cresent. Just hold the pulley with it. If anyone gets a new pump, make sure it has the pulley already on. I had a bad time getting the stock pulley off w/o being too rough on it.
I might be doing it again I think
94ZZJJ is offline
post #10 of 10 Old 09-12-2004, 09:42 PM
lovat
lovat's Avatar
I just changed mine today, and I used a Big ol crescent wrench on it. (Metric, you know ;~) I had to hold the serpentine belt still, and I thought it was not going to come, but luck was with me, and it came right off. This is the first repair in a long time that I did not break anything else, nor scrape any knuckles.... Kinda thought something went wrong!
Anyway, the only hose that was a real problem, was that upper hose with the tiny clearance, I had trouble on re- assembly. I had to clamp my channel locks on it with a hose clamp. The hose clamp was 'squeezing' the handles of the pliers, which were squeezing the working hose clamp into the open position, thereby enabling the installation of the water pump.
Okay,
Greg
lovat is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 06:50 AM
4.0 water pump Katesdad ZJ Grand Cherokee Forum 3 05-23-2008 07:05 PM
Water Pump nmn ZJ Grand Cherokee Forum 16 09-19-2006 01:47 PM
Water Pump sadic1 ZJ Grand Cherokee Forum 5 11-15-2005 04:53 PM
How do I know if its my water pump? grasp ZJ Grand Cherokee Forum 8 11-15-2005 12:08 AM
