Blowing white smoke, but not losing coolant? - JeepForum.com
post #1 of 8 Old 02-17-2013, 07:06 AM Thread Starter
AVR2
So I took my ZJ for its annual inspection, and it failed. The printout says it was blowing "white smoke". This surprised me; I know it's burning oil on idle and I still haven't got round to changing the valve stem seals, but to me, white smoke means that you're burning coolant, and as far as I can tell I'm not.
I completely overhauled the cooling system in the last year - new water pump, rad, hoses, T-stat housing and fan clutch, plus new freeze plugs after one started leaking. I check my coolant level at least once a week, and it never drops. So what's with the white smoke?
I had a look just now, and sure enough the smoke looks white, or maybe *very* light blue, but it certainly doesn't smell sweet - it's a full-on oil-burning smell.
Could a "stop smoke" oil additive cause white smoke as it got burned? I got persuaded into having one added last time I got my oil changed.
AVR2 is offline
post #2 of 8 Old 02-17-2013, 07:20 AM
Crazyhorse92284
Doesnt sound to me like its coolant. If your loosing oil i bet the smoke is caused by unburned oil getting into your exhaust. That would cause a whitish blue smoke.
Crazyhorse92284 is offline
post #3 of 8 Old 02-17-2013, 07:58 AM
PolkaPower
Maybe oil getting past the rings?
PolkaPower is offline
post #4 of 8 Old 02-17-2013, 08:19 AM Thread Starter
AVR2
If only happens on idle, which AFAIK points primarily to the valve stem seals - I'll know for sure after I've changed them. My breather is bone dry with no blow-by oil, and I understand that blow-by is a symptom of oil getting past the rings.
It's the fact that the smoke is white that's had me confused, simply because I thought that white smoke always meant coolant in the exhaust, but I am 100% definitely not losing any coolant.
AVR2 is offline
post #5 of 8 Old 02-17-2013, 04:38 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Burning oil.....plenum gasket.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 8 Old 02-17-2013, 05:08 PM
PolkaPower
Hunter
That's what I thought initially too but he's got the 4. slow.
Is is possibly overfilled with oil? Could it be burning oil while driving but you only notice it while at idle? I'll be interested to know if the seals fix it.
post #7 of 8 Old 02-17-2013, 05:14 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yeah, those guys are always missing 2 cylinders....
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 8 Old 02-18-2013, 03:34 AM Thread Starter
AVR2
Judging by the level when I checked the dipstick yesterday, no
Me too... just don't have the cash for a rebuild or replacement engine, and it needs to pass inspection soon
AVR2 is offline
