Blower motor works when it wants to - JeepForum.com
post #1 of 1 Old 06-22-2009, 12:12 PM Thread Starter
ksturgio
Alright i've got a 97 laredo with 138,000 miles. With the manual climate control. The blower motor works off and on and is usually consistently working but every once in a while it will shut off for 2-3 weeks then it will turn on randomly and start to work again. I've replaced the resistor with a factory replacement unit (which was the wrong one it doesn't have 4 fan speeds just 3). I tested the motor with direct power and it works fine. I'm at a loss of what else to check. Any suggestions.
ksturgio is offline
blower motor - blower motor connector melted BradMB2004 ZJ Grand Cherokee Forum 9 10-14-2014 09:57 AM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 03:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 01:51 PM
'96 Jeep Blower works on Hi only regpugeda ZJ Grand Cherokee Forum 0 07-06-2007 06:24 PM
94 JGC, where is the blower motor relay, and where's the blower motor ground wire go? camosilver ZJ Grand Cherokee Forum 1 08-24-2006 11:15 PM
