Blower motor resistor connector - JeepForum.com
post #1 of 7 Old 10-03-2013, 07:30 AM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Called the dealer to see if I could get a new connector & pigtail for the blower motor resistor & they want $140.00 for it. That's almost what the resistor costs. I've tried 2 from the jy & those are loose & intermittent like the original. I have a new blower & a new resistor. Now I want them to work before winter.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #2 of 7 Old 10-03-2013, 07:48 AM
johns1mj
Check part number 973-421 from dorman products. I believe this is for regular hvac not auto hvac.
johns1mj is offline
post #3 of 7 Old 10-03-2013, 08:07 AM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Thanks that kit doesn't do the trick. May have to solder the wires on & heat shrink.
post #4 of 7 Old 10-03-2013, 09:25 AM
johns1mj
Do you have auto air?
johns1mj is offline
post #5 of 7 Old 10-03-2013, 09:53 AM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Yes it's a Ltd. yes I know it's not a resistor but a module. Local auto parts ppl call it a resister regardless & I have to specify w/auto temp control. I'm going to tack solder & heat shrink each connection individually. Also working on the ac drain leak/clog.
post #6 of 7 Old 10-03-2013, 03:48 PM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
After soldering & heat shrink I have intermittent blower. Did I get a bad one out of the box & now can't return because it's modified?
post #7 of 7 Old 10-03-2013, 03:58 PM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Bypassed the module & wired directly into the blower. Operates totally on high, no control but blower is good. Been fighting a bad new module for a couple weeks off & on thinking the connectors were still to blame.
