Blower motor resistor - JeepForum.com
post #1 of 7 Old 02-03-2007, 12:50 AM Thread Starter
93ZJbeast
A few questions:
1) does 93-98 ZJ's use the same resistor, and
2) does anyone have a pic of where the resistor is? I see many wires but nothing that resembles a removable item.
Thanks in advanced
-Phil
93ZJbeast is offline
post #2 of 7 Old 02-03-2007, 01:19 AM
10achik
I ate what?
10achik's Avatar
Granted this is for the WJ, but check the links within this thread for pic's. It's just below the glove box on the passengers side, closest to the firewall. It screws up into the vent from underneath.
http://www.jeepforum.com/forum/showt...motor+resistor
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 7 Old 02-03-2007, 12:33 PM Thread Starter
93ZJbeast
thanks for the reply, anyone else??? I KNOW one of u guys have done this on a ZJ... help me out!
post #4 of 7 Old 02-03-2007, 01:00 PM
-Joe-
-Joe-'s Avatar
Manual or auto controlled climate?
2 different packs i beleive.
Its on the left side of the blower motor under the passenger dash.. Unplug the harness and 2 screws holding it in..
If its shot it will work on high but no lower settings..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 7 Old 02-03-2007, 08:02 PM
TomStromie
It's a piece of cake to replace if it is anything like my 2002 GC.
http://www.jeepkj.com/forums/viewtop...1531299426b6bb
It took most time to get the electrical connection apart. Be sure to unbolt the resistor first before pulling the electrical connection apart. I didn't and it took two weeks for the torn skin on my knuckle to heal.
TomStromie is offline
post #6 of 7 Old 02-04-2007, 04:20 AM Thread Starter
93ZJbeast
Automatic.
Ok i locatedit but didnt take it out yet... Now if its shot does that mean high should work? It does not work on any setting. And the auto climate control u can set it to like 50 different settings it looks like. Do you think possibly it could be my unit it self? Is their a way to check? Im sick of using this getto switch i have and it only blowes out at hair ripping speed and nothing else
Ill take it out and see if theirs any signs of discoloration or the likes
post #7 of 7 Old 02-04-2007, 06:54 AM
niko
niko's Avatar
If the resistor is bad it should only work on high...but on RARE cases it won't work at all. Try directly connecting the ground that goes into the resistor to the blower motor. If that doesn't work then it's either your switch or a ground to the switch.
I had a similar problem and found that one of the two grounds to the switch was broken. So I just grounded it by sticking a wire from the switch to the nearest metal surface and now I have heat.
Nik
niko is offline
Blower Motor resistor help fumblefingers ZJ Grand Cherokee Forum 8 12-07-2009 10:58 AM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
Blower Motor Resistor jjb719 ZJ Grand Cherokee Forum 11 05-31-2007 04:02 PM
Blower motor resistor eddiecai ZJ Grand Cherokee Forum 0 08-31-2006 07:40 PM
blower motor resistor ljh ZJ Grand Cherokee Forum 0 04-01-2005 07:37 AM
