Blower motor not turning on - JeepForum.com
post #1 of 12 Old 01-30-2013, 08:16 PM Thread Starter
Dre40
Ok I got a new blower motor because the PO had cut the wires and bypassed it to turn it on. Does someone maybe have a copy of some schematics for a 97 ZJ? I don't want to go replacing parts if there's something behind the dash that wont let the blower motor turn on. The PO replaced the fan control Assembly on the dash, but that didn't fix the problem. Any help would be much appreciated.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #2 of 12 Old 01-30-2013, 08:32 PM
jmonty0523
When hooked up, does it turn on at all? Sometimes the blower motor resistor will fry and then it will only yet the blower run on high.
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #3 of 12 Old 01-30-2013, 08:36 PM Thread Starter
Dre40
I get nothing out of it when I turn the switch. I tried to wiggle wires and unplug the switch no luck. I unplugged the blower motor and jumped it to the battery and it runs fine.
Dre40 is offline
post #4 of 12 Old 01-30-2013, 08:41 PM
KoreaZJ
1994 ZJ
Check the connectors on the front of the heater box for pin damage from overheating. There are usually visual "burny marks and meltyness" (author: ratmonkey)
Looks something like this
Some cut the connectors out and splice all the wires together. Or just bypass the connector with the damaged wires, splice together.
KoreaZJ is offline
post #5 of 12 Old 01-30-2013, 08:45 PM Thread Starter
Dre40
Awesome I will look for that tomorrow. Do I have to remove the glove box to get to that connector?
Dre40 is offline
post #6 of 12 Old 01-30-2013, 08:46 PM
JS97ZJ
here
JS97ZJ is offline
post #7 of 12 Old 01-30-2013, 09:48 PM
KoreaZJ
1994 ZJ
Drill out 2 black rivets, remove 4 screws, remove glove box.
Rivets not required for reassembly.
KoreaZJ is offline
post #8 of 12 Old 01-31-2013, 03:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if i don't see it, i can't do anything about it.
ratmonkey is offline
post #9 of 12 Old 02-04-2013, 06:19 AM Thread Starter
Dre40
Hey wanted to thank you guys for the Help. It was that connector behind the dash. melted wire. Repaired and now the blower works. .
Dre40 is offline
post #10 of 12 Old 02-04-2013, 06:41 AM
melk
Get a copy of the FSM in PDF form.... incredibly helpful.
I'm in the process of printing out the whole thing a section or two at a time at work, haha.
melk is offline
post #11 of 12 Old 02-04-2013, 02:02 PM
Camaro16
Ditto - work late, swear lots about clients when there are only a few people in the office, print out next section.
Go to printer, kick it and complain that Xerox can't make a printer that works, and "try it one more time!"
Print next section. retrieve.
Continue for a few weeks - 1800 pages is a LOT!
Camaro16 is offline
post #12 of 12 Old 02-04-2013, 02:42 PM
Katesdad
Katesdad's Avatar
1800 is alot!
I had the same burnt connectors also, with the same fix.
Katesdad is offline
