Blower Motor Control Module - JeepForum.com
post #1 of 5 Old 09-27-2007, 03:06 PM Thread Starter
mlee1steph
Hi Everyone,
I think I need to replace the Blower Motor Control Module and I would like to get the cost of the unit. I've been having the problem with the wires getting hot and loosing contact. The other day I tried to solder the wires to the module and I actidintly crossed the two possitive wires and it blew the fuse under the hood for the blower motor. I replaced that and reconnected the wires correctly and now the motor will not work at all. So how much is it going to cost me now? Thanks for any info.
Michael Lee
mlee1steph is offline
post #2 of 5 Old 09-27-2007, 03:56 PM
Briandl
Hmm, I did the same thing (I didn't have any wiring diagram when I was doing the repair) and after I replaced the fuse it worked fine, strange...
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #3 of 5 Old 09-27-2007, 10:18 PM
benstar10
Originally Posted by mlee1steph
Hi Everyone,
Michael Lee
I just took in mine this past Tue to get the blower motor, resistor (control module) and the harness replaced. It cost me all $650 including labor and tax. I am in Alberta Canada so yours will vary. The parts themselves cost about $500 Canadian - and do not try replacing the resistor only without doing the same to the blower. The blower is probably the cause of the overheating and melting. its sucking too much power
4.7L H.O V8
Transfer Case: NV247
Quadradrive
Stock Suspension
benstar10 is offline
post #4 of 5 Old 09-28-2007, 09:06 AM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
The cost of the module from the dealer here in SW Michigan is $135.
This was for a '95 with automatic climate control.
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #5 of 5 Old 09-28-2007, 06:12 PM
Dodge,Jeep Tech
u get a new wire harness with that module the right way is to take out the dash and repalce the harness but u can do what u want. I do this sorta stuff on th side.
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
Dodge,Jeep Tech is offline
Blower Motor resistor/module duckysbht ZJ Grand Cherokee Forum 12 10-07-2009 04:08 AM
Auto Control Blower motor plug-Repair klockdoc ZJ Grand Cherokee Forum 1 07-11-2009 03:08 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 03:33 PM
help asap I need a Blower motor control module for my wj bobwj ZJ Grand Cherokee Forum 3 01-21-2009 04:29 PM
blower control module mdoug445 ZJ Grand Cherokee Forum 1 12-01-2007 06:12 PM
