Blower motor - JeepForum.com
post #1 of 7 Old 04-06-2013, 05:00 PM Thread Starter
fdawg4ever
Blower motor
Heat still coming out but no fan speed work at all. Could this be a relay or????
fdawg4ever is offline
post #2 of 7 Old 04-06-2013, 06:45 PM
RNMedic
wiring for resistor behind the glove box, shorts out
The only thing more powerful or reliable than a Warn is Chuck Norris getting out and pushing.. from Hussler on JF
RNMedic is offline
post #3 of 7 Old 04-06-2013, 07:04 PM Thread Starter
fdawg4ever
How can I fix that, with new resistor??? I'm not real good with wiring lol
post #4 of 7 Old 04-06-2013, 11:54 PM
KoreaZJ
1994 ZJ
Help JF help you.
Please fill in your Jeep profile info. Year, engine, tranny, etc.
<--- Displays over there.
Which year?
Manual Controls or ATC?
KoreaZJ is offline
post #5 of 7 Old 04-07-2013, 04:01 AM Thread Starter
fdawg4ever
97 jeep grand cherokee Laredo 4.0 I6. Manual controls.
post #6 of 7 Old 04-07-2013, 09:24 AM
flexyxj
2009 XK Commander
Check Blower motor fuse under the hood. IIRC, it's a 30Amp Maxi-fuse.
flexyxj is offline
post #7 of 7 Old 04-07-2013, 02:13 PM
KoreaZJ
1994 ZJ
  • Check Fuse#7 (40amp) in PDC under hood.
  • Blower Motor could be bad. Can be tested by unplugging, then hooking directly to 12v battery.
  • Check the connectors on the front of the heater box for pin damage from overheating. Common problem. There are usually visual "burny marks and meltyness" (author: ratmonkey)
    Looks something like this...
    Some cut the connectors out and splice all the wires together.
    Or just bypass the connector with damaged wires spliced together.
  • Blower motor resistor could also be bad.
KoreaZJ is offline
