Blinker problem - JeepForum.com
post #1 of 13 Old 04-28-2013, 04:08 PM Thread Starter
TitletownZJ
Blinker problem
Yesterday I set the alarm on the ZJ off and tried to turn it off with the remote but it was missing a battery so I popped the hood and pulled the horn fuse. Then went in the house to get new batteries and then turned it off. I plugged the horn fuse back in and now my blinkers and my info counsel dont work. I found a blown fuse so I replaced it and once again it blew any thoughts help anything thanks
98 XJ
98 ZJ
Member of Titletown Jeepers
TitletownZJ is offline
post #2 of 13 Old 04-29-2013, 06:15 AM Thread Starter
TitletownZJ
Bump
98 XJ
98 ZJ
post #3 of 13 Old 04-29-2013, 08:39 AM
KoreaZJ
1994 ZJ
Do you mean horn "relay"...? Problems all started with pulling/installing the relay?
Junction Block Fuse#6 supplies power to turn/hazard flasher, VIC, NSS, day/night mirror.
Disconnect the battery NEG cable, grab an ohmmeter and isolate the short. Seems unrelated to pulling the horn relay.
KoreaZJ is offline
post #4 of 13 Old 04-29-2013, 11:48 AM
ROFLwaffles
It's probably low on fluid.
ROFLwaffles is offline
post #5 of 13 Old 04-29-2013, 04:18 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Great stuff, long lasting and won't freeze in the summer.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 13 Old 05-02-2013, 05:08 AM Thread Starter
TitletownZJ
To funny guys. I found it was the relay nut now it won't start in park so I'm assuming my neutral safety switch is bad since it ing starts in neutral. Any thoughts???????
98 XJ
98 ZJ
post #7 of 13 Old 09-11-2013, 02:06 PM Thread Starter
TitletownZJ
OK I'm still having blinker issues. while my blinkers some times work it would also only start in neutral so that lead me to believe that the neutral safety switch was bad so I replaced that and now it starts in park like it should but now my blinkers only work when I turn the hazards on and off then they work im totally lost please help. Also the overhead console don't work anymore. the fuse is good I've checked that.
98 XJ
98 ZJ
post #8 of 13 Old 09-11-2013, 03:10 PM
eagsc7
1994 ZJ
Yeah, your low on 'blinker' fluid. Lol
My Build Thread: http://www.jeepforum.com/forum/f13/steaks-zj-build-repair-thread-1552698/
eagsc7 is offline
post #9 of 13 Old 09-11-2013, 03:51 PM
Kingr98
2016 JK Wrangler
Isn't there a blinker relay behind the passenger's kick panel? Could that be going bad?
I don't have my field service manual with me to check right now.
Kingr98 is offline
post #10 of 13 Old 09-17-2013, 08:35 AM Thread Starter
TitletownZJ
I replaced it with a brand new one and still nothing.
Hahaha Blinker fluid that so FREAKIN FUNNY if your not going try helping then Shut up!!!!!!!!!!!!!!!!!!
98 XJ
98 ZJ
post #11 of 13 Old 09-17-2013, 08:54 AM
zjosh93
IMS there are separate flasher modules for the hazards and turn signals. If your hazards work then you probably have good wiring after the flasher. I don't remember where the hazard flasher is but my turn signal flasher is above my pedals. Of course mine is a 93 so that may not matter to your 98. A wiring diagram should tell you where the flasher gets power, most likely the multi function switch, and you can start tracing from there.
What have you done to try and diagnose your problem?
EDIT: When you turn the turn signal on does the light come on and not flash or do you get nothing at all?
zjosh93 is offline
post #12 of 13 Old 09-18-2013, 02:34 PM Thread Starter
TitletownZJ
I get noting at all when I try to turn them on
98 XJ
98 ZJ
post #13 of 13 Old 09-22-2013, 01:37 PM Thread Starter
TitletownZJ
Well I got the blinkers finally working. I cleaned the contacts in the multi function switch and replaced the fuses and bingo we for blinkers
98 XJ
98 ZJ
