Blender sound at cold start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Blender sound at cold start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 11-21-2008, 09:57 AM   #1
rflem550
Blender sound at cold start (updated with audio Post #9)
You can hear the noise here:
jeep :: MVI_0128.flv video by rflem550 - Photobucket
When it's really cold outside and I start my Jeep (02 GC V8) for the first time in the morning, theret is a loud sound that sounds like a blender...immediately after startup.....It only lasts a couple of seconds, then goes away and then I hear my normal engine sound.
Any idea what is making that loud noise on cold mornings?
rflem550 is offline   Reply With Quote
Unread 11-21-2008, 09:59 AM   #2
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
I could be the starter remaining engaged for a few seconds too long.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
Unread 11-21-2008, 10:45 AM   #3
doublejz
starter is my guess too
04 WJ with some stuff - see here
doublejz is offline   Reply With Quote
Unread 11-21-2008, 12:17 PM   #4
Merc1973
^^^^^ Ditto
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote
Unread 11-21-2008, 01:05 PM   #5
VulcanJeep
I had an XJ once that did that, but it turned out to be the clutch release bearing (5-speed). Yours is probably the starter, as mentioned previously, but could be a bearing on the belt tensioner, alternator, power steering, or whatever. Unless it gets worse, and lasts longer, it could be quite evasive.
VulcanJeep is offline   Reply With Quote
Unread 11-22-2008, 08:34 AM   #6
4jeepers
I have the same problem, however not so pronounced as yours. I traced it to the alternator bearings by having some one start the GC when I was leaning under the hood. I have new alternator at the ready when old one drops dead.
4jeepers is offline   Reply With Quote
Unread 12-02-2009, 09:24 AM   #7
rflem550
I'm bumping this (almost exactly a year later) because the cold is back.
When i crank my Jeep on cold mornings (around 40 or below) i get this really loud sound from under the hood for about second or two. Sounds like something winding up really fast and loud and then it quits.
Any other ideas or feedback? I haven't been able to trace the sound to any particular place b/c I live alone and do not have someone that can listen under the hood while i crank it (or vice versa).
It's getting LOUD!!!
Unread 12-02-2009, 09:25 AM   #8
rflem550
Oh yeah, I replaced the starter in June because it died. So it's not that.
Unread 12-06-2009, 05:55 AM   #9
rflem550
Unread 12-06-2009, 08:21 AM   #10
newfieZJ
Jeep collector
newfieZJ's Avatar
Originally Posted by rflem550 View Post
I'd say it's your power steering pump . Does turning your wheel when it's cold effect the noise ? It's -1F here this morning , I bet mine makes the same noise when I start it . BTW , the windchill is -17F , brrrr .
I've heard that noise lots before
newfieZJ is offline   Reply With Quote
Unread 12-06-2009, 08:51 AM   #11
4Slow9erHybrid
Mine does the same when it's really cold outside. Probably the power steering pump.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline   Reply With Quote
Unread 12-06-2009, 09:57 AM   #12
ratmonkey
Living dead mod
ratmonkey's Avatar
take your serpentine belt off and start it, see if the noise continues.
ratmonkey is online now   Reply With Quote
Unread 12-06-2009, 10:04 AM   #13
yjjeepn92
yeah my vote is powerstearing. i dont know about taking off the belt and seeing if that does it. but it sounds to me like powersteering
Jeeps are like herpes, they may act up from time to time, but you'll never get rid of em!
yjjeepn92 is offline   Reply With Quote
Unread 12-06-2009, 10:19 AM   #14
rflem550
thanks yall.
i do know my power steering pump has been leaking for a few years.
might need to look into replacing it.
Unread 12-06-2009, 12:48 PM   #15
ratmonkey
Living dead mod
ratmonkey's Avatar
it will tell you if the sound is in the accessory drive.
perfectly safe to start and run a motor without the serp belt.
