Blend Door Servo Testing - JeepForum.com
post #1 of 4 Old 10-09-2009, 05:08 PM Thread Starter
roelze
2002 ZJ
Hey Guys,
I am putting my GC back together this weekend after replacing the heater core, and upgrading the blend doors with the new style, and also the recirc door broke at the hinge. Yes, I have all of the known issues. Here's my question, does anyone know if the door servo motors can be bench tested? I don't ever, ever, ever, EVER, want to pull the dash out of my jeep again.
Thanks,
Rick
roelze is offline
post #2 of 4 Old 10-09-2009, 07:24 PM
RevNL
Yes. I used test leads and a 12v power supply to run them all full-swing before reinstalling the HVAC box.
Just don't run them too far or you'll break the stops on the new parts.
RevNL is offline
post #3 of 4 Old 10-09-2009, 07:26 PM
USA_PRIDE
1979 CJ7
yeah really simple to bench test the door actuators. When I replaced the blend doors and recirc door with the steel heater treaters replacement, it came with a tester but u can make your own. take a 9v battery and two lengths of wire. disconnect the plug to the motor. connect the wires to the battery. touch one wire to each prong on the motor. it will move the doors in one direction. then switch the wires going to the motor (changing polority). it will cause the doors to go the other direction. hope this helps
2011 Wrangler Unlimited Rubicon- Flame Red
1999 Grand Cherokee Limited
God Bless All The Men And Women Who Served And/Or Is Serving This Great Country!
Proud To Be A FF/EMT/Police/Military Club Member #3
USA_PRIDE is offline
post #4 of 4 Old 10-12-2009, 02:04 PM Thread Starter
roelze
2002 ZJ
Thanks for the info guys, that worked great. Happy to report that the Jeep is all back together, and everything is working great. Now I am ready for another Alaska winter........
roelze is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 07:12 PM
where is my blend door mike4089 ZJ Grand Cherokee Forum 4 05-28-2012 07:06 PM
Blend Door aj173pa ZJ Grand Cherokee Forum 12 06-18-2007 02:31 PM
Blend door Ironworker28 ZJ Grand Cherokee Forum 9 03-05-2006 12:41 PM
Blend door on 98 5.9L? gdupjeep ZJ Grand Cherokee Forum 9 12-30-2005 06:05 PM
