Blend door replacement - JeepForum.com
post #1 of 2 Old 08-23-2009, 09:31 AM Thread Starter
curt93t/t
I've heard you need to basically take the dash out, but how much of a pain is it to replace these? Are the doors the problem or is the it motor that controls them? I can't find the manual, but if I remember correctly I got one fault saying travel is too much, can't remember the other one. One last thing, how much do these parts run?
curt93t/t is offline
post #2 of 2 Old 08-23-2009, 09:46 AM
crashcraddock
There are many ways to go about fixing these. Your best bet is to use the search function on this site, the info is unlimited. Also a great site with a complete write up is WJJeeps.com - Jeep Grand Cherokee WJ 1999-2004 and JeepsUnlimited.com Forums - Powered by vBulletin both of these sites have write ups. The jeeps unlimited write up is and addendum to the wjjeeps write up. All info is in here, prices, even what wrench size you'll need to use.
You could go the easy way and use heater treater, or the others like it, but then you lose the dual climate control.(maybe not an issue to you) In the end do it yourself, take time to not misplace anything and save hundreds of dollars. Then you can laugh every time you drive by the mechanic's garage.
crashcraddock is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 08:12 PM
where is my blend door mike4089 ZJ Grand Cherokee Forum 4 05-28-2012 08:06 PM
Blend door - Where to buy? itismejoshy ZJ Grand Cherokee Forum 10 07-03-2008 08:41 PM
ZJ Air/blend door replacement wjs81866 ZJ Grand Cherokee Forum 1 03-26-2007 03:05 PM
Blend door replacement 99wjman ZJ Grand Cherokee Forum 0 01-11-2006 08:36 PM
