Blend Door Replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Blend Door Replacement
Paracord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.comNew! JK/U skid plate system.
Unread 05-19-2015, 12:28 PM   #1
antimattr
Hi all.
I am repairing a few things on my ZJ (Niner) and ended up taking out the dashboard. I had a water leak behind the windshield and because of all the water the blend doors on the air box look very gross. The air box works fine and can be cleaned but where can I find new blend doors? They seem too gross to save and so far I haven't found a "kit" for the ZJ.
Thanks
antimattr is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 12:54 PM   #2
SAR-Swimmer
Try Amazon, they have one listed, under blend door repair/replacement 98 ZJ, $90+ shipping. Might be what you're looking for.
SAR-Swimmer is online now   Reply With Quote Quick reply to this message
Unread 05-19-2015, 01:18 PM   #3
AVR2
Pretty much all the parts relating to the HVAC box are still available from Mopar. I bought a new blend door, a new mode door, various hinges/levers and two door motors.
AVR2 is online now   Reply With Quote Quick reply to this message
Unread 05-19-2015, 04:14 PM   #4
Uniblurb
Uniblurb's Avatar
Below is a real good write-up by coralman on rebuilding the HVAC box. He gets into the new doors with part numbers around post #20 for his 98.
http://www.jeepforum.com/forum/f13/c...build-1828106/
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:04 PM   #5
antimattr
Thanks guys! You rock!
