blend door repair. - JeepForum.com
post #1 of 2 Old 10-25-2009, 12:34 PM Thread Starter
tbone31
blend door repair.
I just ordered the heater treater pro plus recirc kit. I'm having the a/c discharged at my local shop and have a warm garage to pull the dash.
My jeep has 165 000 kms. I know its recommended to replace the heater core and ac evap, but cash is tight. Is there any real way to judge how much life these parts have left in them. I have always had good heat and a/c before the blend door failed. But spending another $200 cdn on these parts is it really worth it? Can anyone comment on their own experiences?
Any tips and advice before undertaking this job would be much appreciated as well.
Cheers
White 2001 Grand Cherokee Limited, Tan Leather, Alpine Deck, 1001 bd and 851x RF amps, Diamond Audio components, 2 12inch RF Subs. 3inch Exhaust.
1993 zj laredo FOR SALE, check the for sale section for details. or email
tbone31 is offline
post #2 of 2 Old 10-25-2009, 01:30 PM
cmonson
I wouldn't worry about the re-circ door. How often do you really use it? If it does break, you can just take it out through the blower motor hole.
I would go ahead and pony up for the heater core though. It will not be any more work.
That said, if you have maintained the cooling system with proper flushes and fluids, then with 165K kms, I would think it would be in OK shape if you want to leave it.
if you do not know the history of the cooling system, or you did not maintain it, go ahead and spend the extra and replace the core. If the system was maintained, leave the core alone.
cmonson is offline
How Much Is The Repair Cost For Blend Doors? (Parts Only?) Briandl WJ Grand Cherokee Forum 8 03-22-2010 02:32 PM
Blend Door Code After Repair Falkon WJ Grand Cherokee Forum 3 03-20-2010 07:57 PM
Connecticut facility to repair blend door? dclough ZJ Grand Cherokee Forum 2 03-27-2007 10:52 AM
blend door repair shortcut from glove box? veso_Ht ZJ Grand Cherokee Forum 2 11-27-2006 10:20 AM
In the middle of Blend Door Repair! Need HELP! 02ovaland ZJ Grand Cherokee Forum 2 09-11-2006 11:51 AM
