Blend Door fix here in Atlanta, GA? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Blend Door fix here in Atlanta, GA?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 07-18-2007, 11:16 AM   #16
cadencedad
dual climate control=1500 dollars or no dual climate contol=135.00 it seemed a worth lose u cut the dash behind the glove box were they cant see it until you remove your glove box completly.I cant see giving jeep any more my money since they wont recal this bull___
cadencedad is offline   Reply With Quote
Unread 07-18-2007, 11:22 AM   #17
JayIV
Well, you could have dual climate control for about 150 bucks in updated parts and 40 dollars in labor.
150 for the blend and recirc doors
40 in labor to evacuate the A/C and then to vacuum and recharge it when ur done.
Thats about how much I spent.
Jay
'94 YJ Sahara D44s F&R SOA 35''s BFG MTs 1-Ton HiSteer
4.7HO Limited WJ 4.5'' Clayton's 32''s For Sale
JayIV is offline   Reply With Quote
Unread 07-18-2007, 11:28 AM   #18
cadencedad
There is no way i could tackle the hole dash we need both vehicles i would be sever days on that one
Unread 07-18-2007, 11:01 PM   #19
Dodge,Jeep Tech
unless u were me and have it done in less then a half day. and hey jayiv who took your dash out for 40 bucks??? hehe never heard of that one. And yes the 1500 would be a dealer doing the job like i said i do it for 700 parts and labor =)
[SIZE="3"]Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
[EMAIL="KKeller608@aol.com"]KKeller608@aol.com[/EMAIL]
[URL]http://kevinsmobilerepair.com[/URL][/SIZE]
Dodge,Jeep Tech is offline   Reply With Quote
Unread 07-18-2007, 11:07 PM   #20
JayIV
Lol, no one took the dash out for 40 bucks. I've taken it out 5 times in the last 4 months for free. 40 dollars is what I pay a buddy at the stealership to evacuate it, and then vacuum it down and recharge it.
Jay
Unread 07-18-2007, 11:12 PM   #21
Dodge,Jeep Tech
got ya hehe almost as good as me now huh ??? =) ANd why do u call it a stealership?
Unread 07-19-2007, 01:24 AM   #22
JayIV
Cause they like to steal your money.
Jay
Unread 07-19-2007, 08:04 PM   #23
Dodge,Jeep Tech
ahh think what u like when it comes down to it most of the time the little aftermarket shops cant do it they ship it over to us and then say they fixed it. I see it all the time here in ATL. Besides I have been to over 400 hours of training just in AC and Electrical to get to Master level so that I can do my job right. Dont get me wrong there are hacks even in my shop I haft to take up the slack that they cant fix or have messed up and so on. Like the other day I fixed a car in 30 min and this dude has had it for 3 weeks and sold there all sorta stuff that was not needed and all that was required was a little wire repair. I wish customers had the choice of choosing who got to work on there car some times hehe.
Unread 07-20-2007, 11:28 AM   #24
JayIV
I'm not speaking specifically in work done, but alot of times on parts too. Or for instance, if you look at the price of a dealership alignment vs. a speed shop alignment, dealership is almost always more. And the speedshops are usually better equipped to handle the modified vehicles, for less money.
Jay
Unread 07-20-2007, 01:01 PM   #25
Wastegate13
Not sure if I should have started a new thread but I'll ask this here anyway. I see the most common symptom is no heat for the blend door problems. I don't care about heat, I live in south FL and it rarely gets cold enough here to warrant it. My problem is poor AC. I have fixed the blower motor connector yet it still doesn't blow very hard and the temp sometimes fluctuates from cool to warmish. Could this be the blend doors as well? I pulled one code from the HVAC unit and it was 55 which is passenger door travel too large IIRC. I have checked the refrigerant level and it is full. Would the heater treater product help me if it ends up being the blend doors?
00 Grand Cherokee Limited: 4.7, QuadraDrive
95 Eclipse GSX: Too Much (435awhp/355awtq)
Wastegate13 is offline   Reply With Quote
Unread 07-20-2007, 01:10 PM   #26
cadencedad
yes
the blend door eather stickopen or stick closed. closed you have no heat open you have no ac.heater treater has a way you can check the codes right from your display.They dont like the heater treater here but ill tellyou its 45 min and 135 dollars.
Unread 07-20-2007, 05:51 PM   #27
nashmd454
well...I guess that wasn't my problem after all.....I only get air from either floor or defrost...really both at the same time...but no where else...I thought it was the blend doors...I guess not...I have both heat and cold....just wish I could get air from the main vents. Anyone out there know how to fix that.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Unread 07-20-2007, 08:47 PM   #28
Dodge,Jeep Tech
96 zj??? is that what u have?
Unread 07-20-2007, 08:49 PM   #29
nashmd454
talking to me??? yes...it is in my sig.
Unread 07-20-2007, 11:13 PM   #30
texster68
HeaterTreater
The blend doors do just what the name implies, they regulate the the opening to the heater core and the AC unit. Looking at the system from the passenger seat, the doors have about 90 degrees of movement. When they are in the vertical position, the AC inlet is blocked and the heater is at full force. When they move to the horizontal position, the heater inlet is blocked and the AC takes charge. The doors can be at any position in between, mixing hot and cold air to regulate the temperature.
When the doors break off, they generally fall down to the horizontal position, blocking the heater input. However, they are not tightly forced to that position, just laying there. If they fall just right, they can be fairly effective blocking the heater inlet. However if they fall crooked, or you hit a big bump, they may only partially cover the heater inlet, and allow unwanted heat into the system. Generally, the heat function is broken and the AC operates at less than max efficiency.
Yes, the HeaterTreater will fix your problem. However, if you really don't care about having heat, you can just bypass the heater core by cutting and splicing the heater hoses under the hood such that the coolant recirculates without going through the core. You can do this for the cost of two hose clamps and a barbed connector. As long as you never need heat, you're gold.
The HeaterTreater fix does involve cutting into the heater box. The work is done behind the glove box and is totally out of sight unless you remove the glove box or crawl up under the passenger side dash. The heater box is a two piece box that fits together kind of like the lid on a tupperware bowl, i.e. it has a tongue and groove along the mating edges to allow the box to be aligned properly when you are assembling it. The cut in the box is kind of like taking a pie slice out of a tupperware bowl, cutting through the lip. When you put it back together, the bottom fits back into the tongue and groove and metal duct tape is provided to seal the cut. The fix is structurally sound and completely sealed. The way the cut is made, it would be hard to screw it up.
I agree that if you HAVE to have the dual control functionality, the "right" fix is to disassemble entire dash, evacuate the refrigerant, drain the antifreeze, completely disassemble the heater system and replace the doors. When we bought the GC, the dual control was a big selling point because my wife has some strange algorithm for comfort in the car. Depending on the angle of the sun, time of day, highway or in town, amount of shade, and general mood, there is a perfect temperature setting that only she can determine at two minute intervals. I didn't bother to tell her that now the passenger side temp control doesn't do anything. She still happily adjusts the display to perfection, even though it doesn't do anything. As long she's happy, I'm happy. (It still drives me nuts when she's driving, but my sanity is hardly worth the $1800 that my dealer wanted to fix it "right".)
If the after-market fix sounds good, great...if not, that's fine too. However, I do want to make the point that the HeaterTreater fix is effective, easy, and is a quality product that will last the life of the car.
Chris A.
texster68 is offline   Reply With Quote
