Blend Door Failure - JeepForum.com
post #1 of 2 Old 08-08-2009, 09:34 AM Thread Starter
Falkon
Blend Door Failure
Since this will cause only cold air to blow onto the windshield in winter, that would seem like a safety defect. Has any one ever filed a complaint w/ the NHTSA
http://www-odi.nhtsa.dot.gov/ivoq/
Don't know if this forum allows a posting of a URL but if so it's above. With what appears tobe so many failures maybe Jeep should be looked at as making a poor design and possible recall. If enough complaints come in they may check it out.
Just for what it's worth.
Falkon is offline
post #2 of 2 Old 08-08-2009, 10:45 AM
Turbonut
If you have some time go through the complaints year by year and you'll spend a day reading about the AZC HVAC system . They are of poor design and literally junk, and they aren't going to help anyone out, except tell you about the updated design and let you fork over about $1200 to one of their dealers for installation/parts.
Same as the junk heated seats, with the new design about $250 each seat, it will be up to the owner to do purchase and install, unless they were covered under the recall campaign. I could go on and on, how about the oil pans that rot out because of the material used? Leaking high pressure PS hose, brokem manifold studs, front brakes/rotors on the earlier WJ's.........
Turbonut is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 07:12 PM
where is my blend door mike4089 ZJ Grand Cherokee Forum 4 05-28-2012 07:06 PM
Did the blend door Airborne Lee ZJ Grand Cherokee Forum 0 10-17-2007 08:12 PM
Blend Door aj173pa ZJ Grand Cherokee Forum 12 06-18-2007 02:31 PM
Blend door Ironworker28 ZJ Grand Cherokee Forum 9 03-05-2006 12:41 PM
