A bit of a dif. exhaust idea for 4.0 - JeepForum.com
post #1 of 3 Old 07-12-2011, 08:50 AM Thread Starter
jfabian
Ok, so I did some searching and couldn't find the answer I was looking for. I have a pretty cooky idea for the exhaust system on my ZJ. I want to do basically and "true dual" exhaust on the 4.0. Take an aftermarket header, cut it where the header tubes combine before the collector, make two collector points (like a newer Wrangler header), run 2inch pipe from there, X-pipe it where the O2 sensor is, then into a Flowmaster 50 dual in/out and then out the back on both sides of the trailer hitch. or to save some effort, use a newer Wrangler exhaust manifold if it would fit and just plug where the two O2 sensors would go. It's something different and unique (isn't that why we drive ZJ's and not Wranglers?), and I am curious how it would sound and if there would be any negative effects. What do y'all think? And if it's been discussed on the forum or anywhere else, let me know! Thanks for reading!
'93 Jeep Grand Cherokee Limited 4.0L, AW4 trans, NP 249 TC, D30/D35 F&R, 3.55 gears, 3.5 inch Rough Country lift, 31/10.5/15 BF Goodrich A/T, 15x8 Rock Crawler black steelies
jfabian is offline
post #2 of 3 Old 07-12-2011, 10:40 AM
1stblack97ZJ
Yes, you could make it work.
Yes, it would probably sound awesome.
No, you would not be able to go offroading with it like that.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #3 of 3 Old 07-12-2011, 12:12 PM Thread Starter
jfabian
Why wouldn't I be able to wheel with it like that? It would be just like every other single exhaust, I would just have two pipes running and would have to make sure I have clearance for the rear axle. And I am going to get it as close to the chassis as possible. This is my DD and I do wheel occasionally, but nothing too crazy cuz I don't want to break anything and since it's my only vehicle I can't have it down for long lengths of time.
jfabian is offline
good idea, bad idea? bustaone ZJ Grand Cherokee Forum 6 02-09-2011 12:36 AM
Custom exhaust idea questions MyZJ98 ZJ Grand Cherokee Forum 8 06-29-2009 09:12 PM
WJ 4" long arm lift with 285/75/16 32.8" good idea or bad idea? Juice_Man ZJ Grand Cherokee Forum 10 06-06-2009 03:49 PM
4.0 WJ pre-cat exhaust diameter/exhaust idea the88thpianoman ZJ Grand Cherokee Forum 2 09-23-2008 01:42 PM
Good idea or bad idea?? Sure Shot ZJ Grand Cherokee Forum 8 10-30-2006 12:23 AM
