Bilstein 5100 available for ZJ with 3" - JeepForum.com
post #1 of 3 Old 11-21-2005, 12:31 PM Thread Starter
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Just called Bilstein. Pronounced 'billstine' BTW. I always called them 'billsteen'. I had to wait until today because all the help was at the Baja 1000. So the PNs for a 93-98 ZJ with 3" lift (2.5"-3.5" should be ok) are
front BE5-6241-H7
rear BE5-A463-H5 (need different lower mount bushing sleeve, see below)
The lengths are approximately 24.5" extended and 15" compressed, which equates to a respectable 9.5" of travel. If you haven't converted the rear lower shock mounts to 1/2" hardware (highly recommended), you will need a 12mm bushing sleeve for each rear shock. Sorry, I failed to write down the PN for the bushing sleeve, but Bilstein has it. I'd say just go buy some 1/2" grade 8 hardware and go that route instead.
I am verifying the PNs and shock lengths with Kolak by email. I'll post back with his reply, or maybe he will.
HighLonesome is online now
post #2 of 3 Old 11-21-2005, 09:59 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Thanks for the update. If you take pics, you could have a post in the Grand Faqs section under Shock replacement!
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 3 Old 11-22-2005, 10:04 AM Thread Starter
HighLonesome
Hunter
I will likely be upgrading my aging UC/DT8000 setup to OME/Bilstein over the year end holidays. I'll take some pics and do a short writeup.
More info thanks to the mighty Kolak:
First, if you buy the shocks from Kolak, make sure you specify 12mm or 1/2" for the lower rear shock bushing sleeve. 12mm is stock.
The front BE5-6241-H7 is 24.6"/13.58"
The rear BE5-A463-H5 is 24.35"/15.11"
There is a slightly longer rear shock that is 25"/15.37". Ask Kolak for the PN.
WJ Bilstein 5100 and KOR bushings? dhughessig ZJ Grand Cherokee Forum 1 05-15-2009 06:25 AM
mounting monotube (Bilstein 5100) shocks correctly? MACHJGC ZJ Grand Cherokee Forum 13 10-15-2008 03:07 PM
Bilstein 5100 or RE mono's? lakailimited06 ZJ Grand Cherokee Forum 14 05-18-2008 06:53 PM
MX6's vs Bilstein 5100 or 5150's King Lerado ZJ Grand Cherokee Forum 16 05-01-2008 07:18 PM
bilstein for a 2.5"BB lakailimited06 ZJ Grand Cherokee Forum 7 09-19-2007 09:12 AM
