the billionth zj electrical problem thread - JeepForum.com
post #1 of 8 Old 05-03-2013, 02:32 PM Thread Starter
970001zj
turned on the heat and the ac came on ,then the blower motor quit came back on quit
its doing this going over bumps while still and if i turn the dial up past half way
any advice on how to fix it ?
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #2 of 8 Old 05-03-2013, 02:58 PM
Afdude88
Everytime i turn my climate control on (i have the auto) the a/c light turns on. Seems normal to me.
On the other issue...sounds like you have a connection problem somewhere within the climate control center. My advice is to get a junkyard one and see if if does the same thing.
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #3 of 8 Old 05-03-2013, 03:00 PM
Afdude88
Oh and your a/c will cycle on and off with the defrost is on. This is a automatic function to humidify the defrosting air.
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #4 of 8 Old 05-03-2013, 03:03 PM Thread Starter
970001zj
the a/c thing is happening on front and feet only , i will try to get to the yard sometime soon and get an auto unit
hope its a 10 dollar part
970001zj is offline
post #5 of 8 Old 05-03-2013, 03:28 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Stupid question maybe, but do you have atc?
Originally Posted by HighLonesome
coralman is offline
post #6 of 8 Old 05-03-2013, 03:32 PM Thread Starter
970001zj
auto temp control ?
yes
970001zj is offline
post #7 of 8 Old 05-03-2013, 03:53 PM
KoreaZJ
1994 ZJ
This is a common cause for blower problems...
Check the connectors on the front of the heater box for pin damage from overheating.
There are usually visual "burny marks and meltyness" (author: ratmonkey)
Looks something like this...
Some cut the connectors out and splice all the wires together.
Or just bypass the connector with damaged wires spliced together.
KoreaZJ is offline
post #8 of 8 Old 05-03-2013, 03:55 PM Thread Starter
970001zj
ill do that asap , btw wow !
970001zj is offline
