biggest tires with 4" or less lift - Page 3 - JeepForum.com
post #31 of 94 Old 03-05-2014, 11:57 AM Thread Starter
000shock
1994 ZJ
I'm still standin by for a pic of a rig with 3.5" and 35's. It's already been said, but with metal, a torch and a welder, anything is possible. This just seems a bit of a stretch, to be reasonable anyways.
shock
slate 94 zj, 4.0, 46RE, 242, lp30/35, 3.73's, 3.5 RC/IRO, 255/75r17 Rubi BFG's on Moab 17's.
000shock is offline
post #32 of 94 Old 03-05-2014, 12:59 PM Thread Starter
000shock
1994 ZJ
Originally Posted by speedbucket
Im throw in a flag on this one. Maybe before you bump stopped? No way yo go lock to lock like that. I had more lift and bump stop and bent the fender out about 3" with the tire. Riot. I agree with timo. I also like up travel. A lot of the long arm kits that flex well are running a 28" shock with 2" up and 10 down. My shocks are 34" shocks and I set mine up for 4" up 10 down. In an off camber situation, up travel can keep all 4 in the dirt.
Unless I'm mistaken, the pic you quoted was with 31's. Not his 33's he has now. Even still, lock to lock looks like it would be pretty tight. But definitely more likely with 31x10.50's vs 33x12.50's.
shock
000shock is offline
post #33 of 94 Old 03-05-2014, 02:29 PM
Timo_90xj
Timo_90xj's Avatar
It really depends what you find reasonable or don't I enjoy fabbing stuff, and I like doing things a bit more involved than bolt- on stuff. Prebuilt parts are often compromises at least to some extent, and I don't like to compromise unless I have to
Here's a picture at full flex and full lock, on 32 x 11.50s and 1.75" BB, 1" bumpstop added in the front. As you can notice I've still got some room to go bigger; as I mentioned 35 x 12.50s would be a damn tight fit, but they should anyways You can't see the backside of the front wheelwell here, but there's about 1.75" room behind the tire @ full lock. Front is about the same.
***Under construction***
Timo_90xj is offline
post #34 of 94 Old 03-05-2014, 03:08 PM
roughknight69
I had to cut/hammer a ton just to have my 33s fit at full lock on 4.5in. Keep in mind these pics were before my iro arms etc.
Build thread
roughknight69 is offline
post #35 of 94 Old 03-05-2014, 03:18 PM
Timo_90xj
Timo_90xj's Avatar
Both of those areas are certainly an issue, but they are an issue with 32"+ tires even at higher lift heights unless ~3" of bumpstopping is added. This is one of the reasons I prefer modifying the wheelwells by cutting & welding, because something has to be done anyways.
As for the control arms, stock CAs (all eight) should be the first things to go from a ZJ if it ever gets wheeled, no matter what lift height. They are nothing more than a huge pain in every possible way
post #36 of 94 Old 03-05-2014, 03:33 PM
nicyousuckk
Just to throw my .02 in there, I'm on 33's with 3.5 and I had to cut the front fenders, cut/pound the pinch seem on the back edge of the fender well, anndd... thats about it.
ADJ arms helped center everything... rear didn't take any modifcations at all.
I'm confident with a bit of extra work (not too much) 35's would work fine. Maybe remove / trim the rear bumper and extend the rear arms slightly.
nicyousuckk is offline
post #37 of 94 Old 03-05-2014, 03:38 PM
roughknight69
Originally Posted by Timo_90xj
Both of those areas are certainly an issue, but they are an issue with 32"+ tires even at higher lift heights unless ~3" of bumpstopping is added. This is one of the reasons I prefer modifying the wheelwells by cutting & welding, because something has to be done anyways. As for the control arms, stock CAs (all eight) should be the first things to go from a ZJ if it ever gets wheeled, no matter what lift height. They are nothing more than a huge pain in every possible way
I feel the same way, it would be awesome to cut/weld new inner fenders like metal cloak does for the wranglers. I agree the stock ca's are a pain my iro ones are so much better
Build thread
post #38 of 94 Old 03-05-2014, 03:46 PM Thread Starter
000shock
1994 ZJ
http://www.jeepforum.com/forum/f22/z...build-2161569/
Hey Roughknight, hit up my build ideas and let me know what you think. IRO arms are somethin I'm considering. Thanks.
shock
000shock is offline
post #39 of 94 Old 03-05-2014, 03:49 PM
roughknight69
Just took a pic of how close my mtr is when turning at full lock even with all the trimming
Build thread
post #40 of 94 Old 03-05-2014, 09:18 PM Thread Starter
000shock
1994 ZJ
Spin off thread. It would prob look pretty ****ty to hijack my own thread!
http://www.jeepforum.com/forum/f260/.../#post20983361
shock
000shock is offline
post #41 of 94 Old 03-05-2014, 10:45 PM
big98tnzj
Im running 6 inches now with 33s and my tire still rubs the inside fenderwell on the driver side in reverse at full lock with the seam cut and hammered.
Sent from my tent in the woods using JeepForum
big98tnzj is offline
post #42 of 94 Old 03-06-2014, 12:12 AM Thread Starter
000shock
1994 ZJ
Originally Posted by big98tnzj
Im running 6 inches now with 33s and my tire still rubs the inside fenderwell on the driver side in reverse at full lock with the seam cut and hammered. Sent from my tent in the woods using JeepForum
Is that something you can clearance with a BFH massage? Or do you not have one in your tent!
shock
000shock is offline
post #43 of 94 Old 03-06-2014, 12:45 AM
big98tnzj
Ive already taken a bfh to my seams and it still rubs on full lock only in reverse. I dont have any rubbing while wheeling. I dont understand it
post #44 of 94 Old 03-06-2014, 02:01 AM Thread Starter
000shock
1994 ZJ
Ive already taken a bfh to my seams and it still rubs on full lock only in reverse. I dont have any rubbing while wheeling. I dont understand it Sent from my tent in the woods using JeepForum
Only thing I can think of from there is if it's just a slight bit of axle wrap in reverse that's causing it to hit.
shock
000shock is offline
post #45 of 94 Old 03-06-2014, 07:13 AM
Dark_Sorrow
1994 ZJ
You have to understand as you lift and the control arms remain the same you pull the axle towards the rear. You need adjustable control arms to push the axle forward again.
I have a 6inch lift with 33's. I just got new tires and I was going to do 35's.... But my control arms would need to be pushed out again and its such a PIA that I said screw it and went with 33
Dark_Sorrow is offline
