Biggest tire on stock niner wheels? - JeepForum.com
post #1 of 9 Old 10-24-2013, 09:45 PM Thread Starter
Ket72
I'm lookin at either 285 R75's or 305 r70's and i plan on adding 1.5 wheel spacers to help clear. Would those be to tall or wide for the stock wheels?
Ket72 is offline
post #2 of 9 Old 10-25-2013, 01:04 AM
jabba974
The 285's might fit, but I would think it would be a very tight fit in the wheel well....My guess, is that with just 1.5 inch lift, 31's would be as big as I would go, but I think a wider rim would work better...
jabba974 is offline
post #3 of 9 Old 10-25-2013, 01:46 AM
BoostinBubba
Should be doable, both of those are about a 33, the 305 will be around 10" tread width, and the 285 around 9". Pretty sure the 5.9 wheels are 8" wide? If so those both fall into acceptable range. As far as the rubbing i honestly have no idea, but if it was a problem I would recommend using a modified WJ control arm as they are bent and clear big tires better, never been a fan of wheel spacers myself.
BoostinBubba is offline
post #4 of 9 Old 10-25-2013, 06:26 AM
Snowfan2
WDUP 16X7.0 Aluminum Wheels
9er wheels are 7" wide. 305/70 is too wide IMO. Your sidewalls will bulge and get hot and it will handle like an 89 Brougham D' Elegance.
Snowfan2 is offline
post #5 of 9 Old 10-25-2013, 06:27 AM
riot1987
what is your current b/s?
Build thread^^
riot1987 is offline
post #6 of 9 Old 10-25-2013, 06:31 AM
riot1987
Niner wheels are.. 16x7 if I remember right? cant think of the b/s. There is a charts in the FAQ's section that might help.
Build thread^^
riot1987 is offline
post #7 of 9 Old 10-25-2013, 09:03 AM
PolkaPower
I wouldn't go past a 11.5" wide tire on a 7" rim. I did on my 95 without issue but I was dumber then.
PolkaPower is online now
post #8 of 9 Old 10-25-2013, 09:04 AM Thread Starter
Ket72
I've seen people on here run 33 12.50's on stock 15x7 rims and not have any issues and also 33 13.50 on 15x8's and no issues? I plan to only run em on the stock rims till i can pick up somethin a bit wider down the road.
Ket72 is offline
post #9 of 9 Old 10-25-2013, 09:34 AM
PolkaPower
Ok well why ask the question then? Just run whatever tires you want.
