Biggest Tire Size for Stock 5.9 - Page 3 - JeepForum.com
post #31 of 31 Old 07-19-2013, 04:30 PM Thread Starter
billyblooshoes
Originally Posted by PolkaPower View Post
Will you be buying quick disconnects for your off road use? If not just put the larger tire in there and bump stop it.
If you don't need discos then you are not going to need much articulation. You do not need articulation in mud. Just over larger rocks, ruts, or trees.
no disconnects. i will most likely not be needing much articulation, as you stated.
billyblooshoes is offline
