Bigger Shocks - JeepForum.com
post #1 of 5 Old 05-05-2003, 07:55 AM Thread Starter
KillerZJ
KillerZJ's Avatar
Bigger Shocks
Can I use shocks for a 2" or 3" lifted ZJ but keep the stock springs? What will it do to the ride quality and control? (the whole point of the is alot more flex until I buy some lift coils). And can I drive without my UCA's or should I not do that?
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #2 of 5 Old 05-05-2003, 02:15 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, you can ride on longer shocks. You could bottom them out and damage them also. They aren't centered to have the full compression and extension if the springs aren't long enough.
Never drive without the UCAs attached. Very bad things will happen.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 05-06-2003, 06:41 AM Thread Starter
KillerZJ
KillerZJ's Avatar
alrighty, thanks. So how do you recommend getting a good amount of flex (for a 2" System or BB) and still be able to run 31-32's? I have heard of a 2" BB and Rusty's 3" shocks on Jeeps Unlimited. It flexes alot.
*Sale Pending*
KillerZJ is offline
post #4 of 5 Old 05-06-2003, 09:19 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Killer,
I would recommend a 3.5 inch lift for you. You have a lot of high quality stereo equipment in the jeep which you would want to keep the same high level of quality on the lift.
The ZJ is not a cheap vehicle to lift and have it work like you would want it to. So, since you have put so much into it so far, I would highly suggest keeping it at a level of quality that you are used to.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 5 Old 05-06-2003, 02:05 PM Thread Starter
KillerZJ
KillerZJ's Avatar
Alrighty, thanks. Your right about putting so much into it.
*Sale Pending*
KillerZJ is offline
WJ: Cheapest shocks for 4" lift, What OEM Monroe shocks fit? iluvtruenos ZJ Grand Cherokee Forum 6 06-29-2009 01:05 AM
bigger spare with bigger new tires? 67jeepstang ZJ Grand Cherokee Forum 4 10-21-2008 07:44 AM
Fox 2.0 Emulsion shocks for wj ?Doetsch tech 8000 prerunner shocks ? genislav ronen ZJ Grand Cherokee Forum 2 06-04-2008 09:31 PM
Doetsch Tech DT3 Shocks vs. Rusty's Performance Shocks ColoradoJeepin ZJ Grand Cherokee Forum 0 05-07-2005 03:24 PM
Air Shocks for -04 (not bags, not a leaf, not spacers, not lifts - but air shocks) Mike_W_04 ZJ Grand Cherokee Forum 1 02-19-2005 01:36 PM
