Big Time fuel pressure relief when I open gas cap - JeepForum.com
post #1 of 7 Old 10-08-2010, 04:05 PM Thread Starter
pbj-tj
94 JGC Laraedo 5.2 quadratrac
190,000 miles
So, this is pretty similar to when you run your tank close to empty open the gas cap and you hear the fumes make a vaccume or hissing sound.
Mine is doing it even when there is a half tank of gas... and its crazy pressure, it litterally relieves itself for almost 10 seconds.
does anyone know what is causing this? Never experienced this on any of my 20 vehicles.
only thing I can possibly think of is a clogged injector or fuel filter causing the pressure build up?
(Building up my 1997 TJ - LS1 V8 Swap and more.. here's my thread)
pbj-tj is offline
post #2 of 7 Old 10-08-2010, 04:37 PM
jeepjones
What about your EVAP canister or lines?
jeepjones is offline
post #3 of 7 Old 10-08-2010, 10:31 PM Thread Starter
pbj-tj
I could look at that thanks, any other ideas?
pbj-tj is offline
post #4 of 7 Old 10-09-2010, 10:21 AM Thread Starter
pbj-tj
really wondering what may be causing this, im not sure if this is common on this year zj? this ever happen to anyone?
pbj-tj is offline
post #5 of 7 Old 10-09-2010, 01:11 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
clogged evap line. the fuel pump can suck the tank hard enough to collapse it if it's not vented through the evap system correctly.
ratmonkey is offline
post #6 of 7 Old 10-09-2011, 09:36 AM
Tmark
is the pressure build up in the gas tank usually always the Evap canister??? what about the purge solenoid??
mine seems to only build up the pressure when I get below 1/4 tank. Would this problem throw a code??
thanks
Tim
Tmark is offline
post #7 of 7 Old 10-09-2011, 10:52 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I had it happen on my 94. So much pressure gas would be ejected (onto me ) when I removed the cap. I got a vented cap and that problem hasn't reoccurred in the last two years. I'm sure my evap system is trashed.
HighLonesome is online now
What are symptoms of faulty fuel pressure regulator/fuel pump Tehnation ZJ Grand Cherokee Forum 4 09-13-2010 11:39 AM
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 08:57 PM
Time to replace oem 225/75/16 tires, open for suggestions. metalgod ZJ Grand Cherokee Forum 2 04-07-2007 12:12 PM
Fuel Pressure Adriansaxton ZJ Grand Cherokee Forum 4 03-19-2007 11:18 AM
Fuel Pressure Adriansaxton ZJ Grand Cherokee Forum 2 03-18-2007 02:34 PM
