BFG Muds & tyre pressure? - JeepForum.com
post #1 of 12 Old 01-31-2013, 01:52 PM Thread Starter
Adam86
I've no idea of the correct pressure l should be running.
Tyres are 245/75/16
Just after what on road pressures you all run? Different front and rear? Seen quite a few on here with BFG muds fitted.
Cheers
Adam86 is offline
post #2 of 12 Old 01-31-2013, 02:15 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Too much and your teeth will fall out. Too little and your tires will wear funny. Somewhere about 35ish.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 12 Old 01-31-2013, 04:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that's over stock pressure. i found my 245 mtr's had the best tread contact at about 30psi. but they were also load range e. i wouldn't go over 32psi in those muds for on highway use.
ratmonkey is offline
post #4 of 12 Old 01-31-2013, 05:04 PM
dnuccio
i run around 35-37 psi in my A/Ts, probably different for M/Ts though
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 12 Old 01-31-2013, 05:47 PM
Trick440
1994 ZJ
I dont get it why wouldn't you run 32?
Offroad drop to 20.
Trick440 is offline
post #6 of 12 Old 01-31-2013, 08:03 PM
jetjr91
I run my 32" km2 s at 33 psi front and rear. They do great.
jetjr91 is offline
post #7 of 12 Old 01-31-2013, 09:56 PM
WhiteOut
WhiteOut's Avatar
Originally Posted by Trick440 View Post
Offroad drop to 20.
You want to air down for more traction when you are offroad.
As for on road, do the chalk test. Put a think band of chalk across the tread and drive around the block a bit, adjust tire pressure until it wears even. It will be different for every Jeep, I ran my KM2s at 28psi
WhiteOut is offline
post #8 of 12 Old 01-31-2013, 10:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
wider tires= lower pressure on road. the chalk test is the only way to be positive you're running the best pressure possible
post #9 of 12 Old 01-31-2013, 10:50 PM
jnicewan
I dont run lower than 12PSI for the trail wiithout bead locks and on the street its somewhere between 20-25psi.
jnicewan is offline
post #10 of 12 Old 01-31-2013, 11:40 PM
ZJMatt
When I had my 32" BFG muds I ran about 30psi for street pressure. For off-road, I found that they were just about worthless until you got to around 18psi.
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #11 of 12 Old 02-01-2013, 10:47 PM
Kur
on both my stock tires (back when i was stock) and my 33in mtr/k i run 30psi on the street. seems to be wearing just fine. offroad I take it down to 13.
Kur is offline
post #12 of 12 Old 02-02-2013, 09:23 PM
JohnnyZJ
Offroad drop to 20.
i run on the street at 22 psi
32 would be way to much.
its simple. you run at a tire pressure where you get even tire contact with the ground. if i put 32 in mine, the outer lugs won't ever hit the pavement. that will make them wear funny (called cupping)
you want to run as much air as possible while keeping a constant contact patch. that is going to differ based on tire size, rim size etc.
07' JKUR rollin on 35s
JohnnyZJ is offline
