Best way to up grade the 5.2 in ZJ? - Page 2 - JeepForum.com
post #16 of 24 Old 02-13-2012, 03:02 PM
PolkaPower
You will sure feel the difference with the K&N FIPK because it has way less restriction than the OEM. Unfortunately way less restriction means that it doesn't filter the air for crap. You may as well stick some panty hose on the end of your stock air tube. You will get the same results. Waste of money IMO.
PolkaPower is offline
post #17 of 24 Old 02-13-2012, 03:25 PM
JrMechanic
Swapping a good running 5.2 for a 5.9 is a waste to only gain .7 liters of displacement with no other benefits. I recently built a 5.2 for my buddy's 97 ZJ. I did some bowl blending and porting on the stock heads, cut the intake runners and smoothed them out, installed a cam from Hughes (.512/.520 lift) with matching springs and retainers, and degreed it in and used a double roller timing set. This combination made for a torque monster. It's a little sluggish off the line, due to the short intake runners, but after 2,000 RPM's it screams until redline. It easily would blow the doors off a stock 5.9.
That is on the stock PCM, injectors, and TB. With an SCT tuner, larger injectors, and a 52mm TB, it would be ridiculously fast for a mildly modded Jeep.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #18 of 24 Old 02-13-2012, 04:50 PM
AlexGarrett
Anyone know where we can find a 52mm tb? I've been looking for quite a while to buy one as I don't have the equipment to do this myself
AlexGarrett is offline
post #19 of 24 Old 02-13-2012, 05:00 PM
PolkaPower
You can take it to a local machine shop and they will most likely do it for much cheaper than what you would pay otherwise. http://www.thefastman.com/throttlebodies5x.php
post #20 of 24 Old 02-13-2012, 05:14 PM Thread Starter
xXmotox87Xx
That actually works? Out of what year and size ford mustang engine?
xXmotox87Xx is offline
post #21 of 24 Old 02-13-2012, 05:25 PM
PolkaPower
You can do ford 24# injectors or Dodge neon 703 injectors. What ever you find at the JY first.
post #22 of 24 Old 04-14-2015, 09:00 AM
NewTo98JeepGC
I know this is an old thread but what year and model are the Ford injectors from? What year and and model for the Neon?
Thanks.
NewTo98JeepGC is offline
post #23 of 24 Old 04-14-2015, 07:06 PM
fishermandave95
97 Dodge Caravan Base 2.4L
97 Dodge Caravan SE 2.4L
97 Plymouth Voyager Base 2.4L
97 Plymouth Voyager SE 2.4L
97 Chrysler Sebring JXi 2.4L
96-97 Chrysler Sebring JX 2.4L
96 Plymouth Breeze Base 2.0L
97 Chrysler Cirrus LXi 2.4L
95-97 Chrysler Cirrus LX 2.4L
95-97 Dodge Neon Base 2.0L
95-97 Dodge Neon High Line 2.0L
95-97 Dodge Neon Sport 2.0L
95 Dodge Stratus Base 2.0L
95-97 Dodge Stratus Base 2.4L
95 Dodge Stratus ES 2.0L
95-97 Dodge Stratus ES 2.4L
95-97 Plymouth Neon Base 2.0L
95-97 Plymouth Neon High Line 2.0L
95-96 Plymouth Neon Sport 2.0L
JEEP WAVE Y'ALL
I FISH THEREFORE I AM !!
fishermandave95 is offline
post #24 of 24 Old 04-18-2015, 04:35 PM
NewTo98JeepGC
Thanks
5.2 , grand cherokee , upgrade
radio up grade Ryan218 ZJ Grand Cherokee Forum 5 10-18-2010 12:48 PM
what brand of oil and grade are you using? 2000gt WK Grand Cherokee & XK Commander Forum 15 09-06-2008 07:41 AM
Premium Grade Gas highryder08 ZJ Grand Cherokee Forum 20 01-04-2008 05:25 PM
grade of fuel for Overland greygrand ZJ Grand Cherokee Forum 19 02-09-2007 07:14 AM
oil grade for 4.0 ? hinchcliffe ZJ Grand Cherokee Forum 8 04-17-2006 03:26 PM
