Best way to replace Engine/Motor Mounts. - JeepForum.com
post #1 of 6 Old 07-29-2011, 12:06 AM Thread Starter
imajeepman
Shoot!
imajeepman is offline
post #2 of 6 Old 07-29-2011, 12:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
With a wrench.
ratmonkey is offline
post #3 of 6 Old 07-29-2011, 07:03 AM
speedbucket
and maybe a socket on the passenger side
"Shoot!"
firearms are not a viable option!
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 6 Old 07-29-2011, 08:04 AM
KJK
It's a pretty straight forward procedure. The bolts on the driver's side are quite a PITA but doable. I placed a piece of wood on a floor jack and positioned it under the oil pan. You can slowly apply pressure with the jack until you can just slide out the motor mount bolt and then remove the mount. Do one side at a time to keep everything aligned.
***Safety note!***
You'll be working in a confined area with your hands between the engine and the frame rail. Get a few scrap pieces of 2x4's or something and stuff them between the oil pan and the cross member after the engine is jacked up. This will save your hands in the event the jack slips or fails.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #5 of 6 Old 07-29-2011, 08:14 AM Thread Starter
imajeepman
Awesome guys! Those are a given...I go about it by raising the engine with a 4 by 4 on top of a floor jack (Never use metal on metal). Wrench's must be used on driver's side and socket w/extensions on the passenger side.
Does anyone know if you need the rubber bushings that come with replacement mounts? I received 2 with my right (only installed and one loose for the other side upon installing middle bolt) and only 1 with my left.
Just thought I would start a reliable source of information to help keep Jeep's running and climbing, appreciate all the time and information made available.
Always carry safely! - Pro NRA!
post #6 of 6 Old 07-29-2011, 08:19 AM Thread Starter
imajeepman
Good one KJK! Nice side *****Safety Note******!!
motor mounts for a zj tsill ZJ Grand Cherokee Forum 0 05-23-2010 12:43 PM
New Motor Mounts cowboy63b ZJ Grand Cherokee Forum 0 12-05-2009 10:36 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
motor mounts peepmyjeep00 ZJ Grand Cherokee Forum 9 01-15-2008 03:37 AM
Now It's Motor Mounts.... nbjly ZJ Grand Cherokee Forum 2 05-09-2006 06:44 PM
