Best way to remove fan clutch? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Best way to remove fan clutch?
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOffset Tie Rod Kit From RuffStuff!
Unread 09-24-2011, 02:32 PM   #1
rfd499
My 96 JGC 5.2L has 256k on it and the water pump let go today. I replaced it several years ago with around 140k and remember the fan clutch being a pain in the rear. What are some tips on removing it without a spanner to hold the pulley? Tried search but I dont have premium membership. Thanks
rfd499 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 02:47 PM   #2
tennman1990
I wedged a wrench between one of the bolts andd the pulley and used my left hand to hold it still while trying to get one of the nuts off the clutch with another wrench and my right hand. Repeat for the others. Not the easiest but deffinately the cheapest.
From ZJ to TJ.
tennman1990 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 03:37 PM   #3
Mike97ZJ
YUP! Same here. I believe I used a long handled box end, but any wrench will work.
Mike97ZJ is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 04:12 PM   #4
kachink
I think the previous two guys are talking about the 4.0, which has 4 smaller bolts holding it on. Your 5.2 has the one hex that threads onto the end of the shaft itself.
The Haynes manual suggests pressing on the belt to put extra pressure on the pulley, but good luck getting enough pressure to break it loose. Here's a pic of what worked for me. The red arrow is pointing to the chuck key from my drill motor inserted into one of the holes on the face of the pulley. My biggest screwdriver went under the key then over the top of the shaft. I had a helper pull up on the screwdriver while I beat on a pipe slipped over the end of the pipe wrench for more leverage.
kachink is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 05:35 PM   #5
frenchface
I had to take mine out with the fan still attached to the pump. I then put it in a vice and i still struggled a little to get it off
95 Grand Cherokee aka Sargent Hoss
5.2L, 46RH, NP249
frenchface is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 06:49 PM   #6
blackjack12982
1994 ZJ
If you've got access to an air compressor, check the parts stores to see if you can rent a "fan clutch removal" tool. It goes on an air hammer and will take the fan clutch off in seconds.
blackjack12982 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 07:28 PM   #7
Joeyicu
or if you have access to an air compressor just tap it with an air chisel with a regular tipped attachment on it, it will come right loose
I removed mine with the pump still hooked to it, because I was going to electric fan, so that process works to, then when on the ground you may be able to manipulate it a little better
{2005 WK Hemi }(1998 ZJ 5.2 - 3.5 IRO 31s) [1984 F250 6.9]
Joeyicu is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 08:13 PM   #8
Mike97ZJ
Yeah, 4.0 here. Didn't realize they had two different setups. Sorry for the mis-information.
Unread 09-24-2011, 08:24 PM   #9
Crasher
I just put a 15" adjustable wrench on the nut of the clutch with the handle straight up. Then hold the tensioner with a wrench to get the belt tight and hit the handle of the adjustable wrench with a hammer and the clutch came free. You can then remove the lower part of the shroud and remove the clutch and fan out the bottom, or remove the fan, clutch and entire shroud at the same time. I've done it both ways.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 37" Mtr's, much more
97 TJ Built Juggy
Crasher is offline   Reply With Quote Quick reply to this message
Unread 09-25-2011, 04:43 PM   #10
Foundrydude
Leave the belt on for starters.
First just try using a big wrench and smacking with a hammer. The blow has a better chance of loosening than slow force applied by hand.
If that fails use a large screwdriver against one of the pulley bolts, then do the hammer trick. You're kind of working against yourself since the large nut is one of the pry points, but it'll work.
Most guys that struggle take the belt off first. It's twice as difficult with the belt off.
good luck
Foundrydude is offline   Reply With Quote Quick reply to this message
Unread 09-25-2011, 05:01 PM   #11
RTYauch301
i usually use a torch to heat it up the correct size wrench and a rubber hammer takes about 10 minutes
RTYauch301 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2011, 07:56 PM   #12
rfd499
Thanks for all the info. I used a bolt through a pulley hole along with a small pry bar to create the leverage point and it worked great. I Cleaned the engine compartment when I was finished with pump replacement to help locate any leaks. Thanks again.
Unread 09-25-2011, 08:02 PM   #13
98318242
THIS! My friend and I spent prob 2 hours trying to get that off and someone suggested putting a big wrench on the nut and giving it one good hard whack with a hammer and being at our wits end we gave it a try and first hit broke it right loose.
98318242 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2011, 07:22 AM   #14
AVR2
FWIW, you don't have to spend crazy money on the official tool. Lisle sell a fan clutch spanner that works for Jeep, GM and Dodge vehicles, you can get it online for about $26.
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2012, 06:56 PM   #15
rsandwick3
Sorry for the late post, but I just did this over the weekend and wasted a couple hours, since I couldn't find a spanner in stock nearby, trying all sorts of things to crack that nut, until...
With the belt off and a heavy duty strap wrench (I used the red one from the like $12 set of two Craftsman ones from Sears) around the water/fan pulley and arranged to be blocked by the crank pulley, it came off without hesitation.
The loaner tool from Advance had a 3/8" drive hole so I was able to add some leverage length with the "poor man's breaker bar" (AKA a 12" extension, a 4" extension, and a 7/8" deep socket over the end of a 3/8" ratchet handle -- I suppose "don't do this at home" rules apply to that move), which probably made it easier, too.
It was a little bit of a PITA to get situated and tight around the pulley, but way more than made up for that in reduced effort on the fan clutch removal.
I've seen a couple people say no on the strap wrench, but I have a feeling they just didn't have it tight around the pulley. Hope this'll save someone some headache!
rsandwick3 is offline   Reply With Quote Quick reply to this message
