Best value longarm kit? Need 5.5 Inch, and replacing wear parts... - JeepForum.com
post #1 of 14 Old 04-29-2013, 04:26 PM Thread Starter
locohosa
So, my beautiful Jeep is coming up on 300k and she needs a bit of love in the steering and suspension. I have also wanted to start playing in the trails again, so I figure that I may as well go nuts! Lift it like I mean it, and make the steering as tight as it was in 1993. The name of the game is value, best bang for the buck.
My goal is to replace all the worn out parts in the suspension at the same time as installing the lift kit. Itís safe to assume that tie-rod ends and ball joints are warn out. I also want to replace the bushings in the suspension and steering.
For the lift I think I have decided on a 5.5 inch long arm kit. Just still researching brand options.
Thatís right, I want it all! I want excellent Flex, Street Manners, AND Affordability.
The POINT:
What is the best value in longarm 5.5 inch kits?
What other parts will I want to replace that are not part of the kit?
I know, most of yaíll are going to tell me to use the search, and trust I am doing that too. Just seeking out some input from the ZJ Guruís.
locohosa is offline
post #2 of 14 Old 04-29-2013, 04:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
all the kits that are worth buying are about the same price. iro and re are the lower choices i'd be after, then tnt, then clayton. tnt and clayton require welding where iro and re are optional to weld the brackets on. the re and iro use an inferior rear 4 link and track bar design though.
ratmonkey is offline
post #3 of 14 Old 04-29-2013, 04:44 PM Thread Starter
locohosa
RatMonkey, just want to say thanks for all your valuable contributions to these boards. You sir, are awesome.
My steering feels loose already, what other parts and pieces should I replace that could help tighten up the steering while I am at it?
locohosa is offline
post #4 of 14 Old 04-29-2013, 04:54 PM
riot1987
Tre's, ball joints. There is an adjustment on the steering box to tighten it up a bit as well.
Build thread^^
riot1987 is offline
post #5 of 14 Old 04-29-2013, 04:56 PM
riot1987
The POINT:
Everyone bashes their products (myself included) because most of them suck.. I however am really happy with my RC longarms. I had a few minor problems with them that were easily resolved. Look into it
Build thread^^
riot1987 is offline
post #6 of 14 Old 04-29-2013, 05:31 PM Thread Starter
locohosa
Thank you! I only found a four inch long arm kit on RC, did I miss the 5.5?
I spotted this kit: LINK and it looks slick, it also states that its a three link, seems to not be overly expensive. Am I missing a big huge downside?
locohosa is offline
post #7 of 14 Old 04-29-2013, 05:48 PM
riot1987
No they just make a 4".
IRO makes a good product. I like that you get 8 adjustable arms with the RC kit. The IRO doesnt have rear long arms. IRO would probably be a better product but again, I havent had any issues with weak/pre mature wearing of parts on my RC long arms.
The RC track bar is trash. I ended up with an IRO double sheer.
Build thread^^
riot1987 is offline
post #8 of 14 Old 04-29-2013, 05:48 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
only short arms in the rear and it's not a 3 link, it's a radius arm missing one of the axle side upper joints.
post #9 of 14 Old 04-29-2013, 05:49 PM
riot1987
The RC lift has a similar 3 link front however, it is adjustable.
Build thread^^
riot1987 is offline
post #10 of 14 Old 04-29-2013, 05:51 PM
riot1987
That IRO kit is what youd call a "radius arm" kit? I always wondered what a radius arm kit was.
Build thread^^
riot1987 is offline
post #11 of 14 Old 04-29-2013, 08:00 PM Thread Starter
locohosa
So how would you say this compares to a short arm kit? I mean, Im ok if its not the top of the line, does this fit the bill as being a good value?
Thank you!
locohosa is offline
post #12 of 14 Old 04-29-2013, 08:11 PM
riot1987
Anything over 3" youll need adjustable arms. Not necessarily long arms. At 5.5" La's would def be an advantage. If you really want a set of long arms for a better price though Id honestly look into RC you can add spacers for cheap.
Build thread^^
riot1987 is offline
post #13 of 14 Old 04-30-2013, 09:38 AM
speedbucket
Radius arms : mounts at one location at frame and top and bottom at axle. They are notorious for unloading coming out of compression leading to obvious instability
Iron is a hybrid with one radius arm and one single lower.
3 link- two single lowers and an individual upper.
4 link - 2 uppers and 2lowers
Triangulated 4 link- either the uppers or lowers are triangulated from frame to axle eliminates track bar
Double triangulated 4 link. Both uppers and lowers are triangulated. This is the most stable but impossible to do on the front with out an insane amount of lift
Thank you!
do it once is all I can advise and I have had lots of problems with RC
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #14 of 14 Old 04-30-2013, 04:10 PM
darkhelmet
im thinking of doing the IRO LA 5.5 kit then down the road getting the claytons rear LA kit... heard it was a fairly decent mix for the "budget"
98 Grand Cherokee 5.2l converting to a cheap trail rig
http://video.adultswim.com/robot-chicken/our-newest-member-calvin.html
ZJ's: If you dont know what it is you cant afford it.
darkhelmet is offline
