Best Spot in the Firewall? - JeepForum.com
post #1 of 5 Old 12-20-2002, 11:11 AM Thread Starter
Beachead19
Beachead19's Avatar
Anyone have any directions or pictures as to where the best hole is in the firewall? I'm tryin to run a power wire. Thanks for any help!
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #2 of 5 Old 12-20-2002, 11:17 PM
scubatch2
I used the same hole as the hood release cable.It's alittle tricky but it worked for me.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #3 of 5 Old 12-21-2002, 07:02 AM
Black96ZJ
I went through the passenger door frame.......ran the wires up the passenger side, to where the glove box is. Then there is a hose around the wires for power windows/locks, etc. cut a hole in that and ran the wire through that and fed the wire up the fender, into the engine compartment. after that, ran the wire under the lip that the hood rests on, then ran it to the battery.
Black96ZJ is offline
post #4 of 5 Old 12-21-2002, 09:06 AM Thread Starter
Beachead19
Beachead19's Avatar
Are you talking about the flexible black tube that runs into the door? If so, that sounds like a good idea.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
post #5 of 5 Old 12-23-2002, 09:38 AM
Black96ZJ
yes, that's the part I was talking about. make it easy on yourself and start from the battery, and work back. this is so that you can feed the power wire down the fender, in stead of pushing it up. If you already started, and have to do it the hard way (like I did the first time) then attatch a coat-hanger to the power wire, or something substantial like that, to make the wire easier to feed.
Getting through the firewall in 99 WJ Kheeney5 ZJ Grand Cherokee Forum 0 12-16-2009 05:55 PM
Safe spot to drill through firewall Linus ZJ Grand Cherokee Forum 14 01-15-2009 01:14 PM
Firewall help madcabbie ZJ Grand Cherokee Forum 4 01-29-2006 11:43 PM
Getting through the firewall ItsJustJeep ZJ Grand Cherokee Forum 1 11-23-2004 01:10 PM
firewall rJEEP ZJ Grand Cherokee Forum 7 01-21-2003 09:45 PM
