Best lift to upgrade to long arm later - JeepForum.com
post #1 of 7 Old 04-06-2013, 07:20 AM Thread Starter
Badphish
I'm looking at short arm lifts with the idea of upgrading to arms in the near future. I want to swap a hp30 and 8.8 and regear and lock first though. So my question is what lift would you go with in the 4-5 range? I'm looking at the Iron Rock 4.5 kit. My only concern is that it uses stock arms. How will the stock arms work and hold up?
Badphish is offline
post #2 of 7 Old 04-06-2013, 07:24 AM
WhiteOut
WhiteOut's Avatar
Do everything at once, cheaper in the long run. Also, if you plan to swap from a LP to HP Dana 30, the IRO front arms will have to be changed out too, and they no longer swap the ZJ arms for XJ arms for the price of shipping.
As for which kit, I would put my own together if I was you. You can choose the best parts from all the manufacturers that way.
WhiteOut is offline
post #3 of 7 Old 04-06-2013, 07:57 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Email kolak from my SIG. He'll hook you up.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 7 Old 04-06-2013, 08:02 AM Thread Starter
Badphish
Looking at the iro kit it has both front and rear trac bars which most other kits don't have just no arms which If the the stock arms will work short term, I'm not spending money on parts I'm going to swap out in a year. I'll beputing the hp30 under it when I upgrade to front long arms so will get the right long arms then
Badphish is offline
post #5 of 7 Old 04-06-2013, 01:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If doing long arms, the best ones don't use stock style brackets. save up, wheel what you have, do the long arms and axles at the same time.
ratmonkey is offline
post #6 of 7 Old 04-06-2013, 07:30 PM Thread Starter
Badphish
Thats kinda what I'M thinking with going with iro kit is I can upgrade with there front long arm upgrade and for the rear a claytons type set up
Badphish is offline
post #7 of 7 Old 04-06-2013, 08:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Thats it though, the Clayton rear requires different brackets for the uppers.
And I'm not a fan of the iro cross member. Have to drop the front suspension with the cross member when doing transmission or transfer case work.
