best and easiest way to get positive traction - JeepForum.com
post #1 of 27 Old 11-14-2012, 06:05 PM Thread Starter
93zjgrand
Whay is the easiest and best way to get postive traction on a budget, that not to hard to install
93zjgrand is offline
post #2 of 27 Old 11-14-2012, 06:20 PM
iser
weld your spider gears. but it won't really be a dd anymore.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #3 of 27 Old 11-14-2012, 06:34 PM
Jeep318
There a right way or an easy way. Lockers are the right way, welding gears together is the easier cheaper way, do it right the first time and you'll be happier you did, I recommend air lockers, air lockers are best if you ever plan to drive on ice or snow. Also consider adding a set of tires that are designed for what kind of terrain you will be driving in most.
Jeep318 is offline
post #4 of 27 Old 11-15-2012, 11:00 AM
captainpolska
Aussie locker would be a fairly cheap and easy install if you are on a budget. I think a good set of tires would be better than a locker and crappy tires though. Your question is a little to vague to answer fully.
captainpolska is offline
post #5 of 27 Old 11-15-2012, 12:00 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
For the 93, you can put a detroit locker in the back and a limited slip up front.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 27 Old 11-15-2012, 12:54 PM
Technohead
An Aussie or Spartan locker in your rear axle is BY FAR the single best modification to improve offroad capability. Total cost is about $300.
-Eric
Technohead is offline
post #7 of 27 Old 11-15-2012, 01:24 PM
bananaslug
FREE: just tap your brakes when you are one-wheel spinning. it will send some torque to your wheel thats just sitting there.
bananaslug is offline
post #8 of 27 Old 11-15-2012, 01:59 PM
JohnnyZJ
ebrake will accomplish this too. that is, if you have a ZJ that has a working one lol.
aussie or spartan locker all the way
07' JKUR rollin on 35s
JohnnyZJ is offline
post #9 of 27 Old 11-16-2012, 12:37 PM
phbrown
1994 ZJ
a fat chick sitting by the wheel that is spinning
1994 Jeep Grand Cherokee Laredo| stock| 231 transfer case| 4.0L
phbrown is offline
post #10 of 27 Old 11-16-2012, 02:46 PM
cwness
Does this include installation? If so where's the best place too get these
parts?
CW
cwness is offline
post #11 of 27 Old 11-16-2012, 03:15 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I thought lockers snapped D35 axles pretty easily?
HighLonesome is offline
post #12 of 27 Old 11-16-2012, 07:55 PM
biggoofy
O they do but that's another thread all together.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #13 of 27 Old 11-19-2012, 04:57 PM
tazz33
Keep all 4 tires on the ground would help?
1998 niner!!!!! K&N, BFG All Terrains, MSD coil, Taylor Thundervolt wires, Superchips Programer, Kolak 3" tailpipe, Magnaflow highflow 3" Cat, MBRP 3" chambered muffler, MBRP 3"-3 1/2" dual wall stainless tip, and gonig to be more to come!!!!!!
tazz33 is offline
post #14 of 27 Old 11-19-2012, 05:55 PM
Trick440
1994 ZJ
Where the hell you guys get aussie and spartan?
If your getting a locker, make it a Truetrac from Detroit Locker. Its strong, cheap, streetable, and easy to install. Don't get anything else unless you want something selectable.
Trick440 is offline
post #15 of 27 Old 11-20-2012, 03:30 PM
JohnnyZJ
tru tracs not even a locker........ its a limited slip.... AND........ not a locker. do not refer to a trutrac LSD as a locker. if you do prepare to be laughed at.
trutracs also are not easy to install. you have to essentially do another gear setup. hopefully it goes together the first time but if it doesn't........ lots of work.
or perhaps your confused and meant a 'powertrax'? which is the same as an aussie.
JohnnyZJ is offline
