Best Desert Cooling Systems, Radiator, Transmission, Power Steering - Page 6 - JeepForum.com
 3Likes
post #76 of 244 Old 07-27-2012, 11:20 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Depending on how much cooler the motor is running, I'd put it back the way it was. You've got the niner efan pulling air across the trans cooler already. Adding another efan would be a hassle.
Odd how my trans ran cooler when I bypassed the rad cooler. But my motor is running too hot to begin with.
The cooler in your link is the next size up from the cooler in my pics. They are made by Hayden in Australia. I'm pretty happy with it.
HighLonesome is offline
post #77 of 244 Old 07-27-2012, 11:33 PM
PolkaPower
I was thinking about that as well. It's just so anti climatic to put it back the way it was. I am draining and flushing the coolant tomorrow and probably doing an 80/20 water coolant mix with waterwetter. I probably don't need the fan but it would be nice insurance on those 120* days out on the rocks when your moving 2 mph. I would just wire it to a switch in the cab. I was thinking about getting smaller fan and putting it on the aux cooler right in the corner where the hot line in connected.
PolkaPower is offline
post #78 of 244 Old 07-27-2012, 11:47 PM
jtackerman28
Do the fan! It will save you radiator coverage. And move the air faster. Both which are pluses! You could use one of the small ones off a neon with 2 fans or any fwd car
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #79 of 244 Old 07-27-2012, 11:55 PM
PolkaPower
The fan has to be no more than 2" thick. Cameleer found one I am thinking about. It won't really save any coverage since the cooler I have on there now takes up a little more than half the condenser. I'll probably end up getting both and blasting the budget I wanted for this. Oh well. You know how it is when you get your mind on something.
post #80 of 244 Old 07-28-2012, 12:38 AM
ilive4cars0122
Originally Posted by HighLonesome
The fan itself is not the only point of failure. Relays, sensors, fuses too. But just carry some wire so you can hook the fan directly to battery if needed.
Radiator came in. It weighs virtually nothing. Says Silla on the box. And the rad cap is much smaller than stock. I'm going to give it a shot.
Im thinking of getting that silla one. Let us know how it works for u. I did notice that radiator cap looks different. Wonder if you could put a better stant cap on there.
ilive4cars0122 is offline
post #81 of 244 Old 07-28-2012, 08:16 AM
HighLonesome
I should have it running by next weekend. Like I said I will pressure test it cold first. Yea the cap worries me but its probably a common PN...I sure hope anyway.
post #82 of 244 Old 07-28-2012, 08:27 AM
HighLonesome
Polka this is the cooler I have. I haven't gone above 215 since I bypassed the rad. Temp measured at the pan. I do have a big finned aluminum trans pan that surely helps. I had the DC Controls box running my Mopar fan at least 20% all the time. If you are stock niner, I think there are times when the fan isn't running at all.
http://www.jegs.com/i/JEGS-Performan...arentProductId=
post #83 of 244 Old 07-28-2012, 10:28 AM
PolkaPower
If you are running 215 at the pan I bet your hot line temps are 250 maybe more. I want mine to read max 215 coming out of the trans during load in hot slow conditions. I don't know if that's possible yet though. I read someplace that the e fan hit high when the ac is on or when temps get really high. Otherwise it's just on low.
post #84 of 244 Old 07-28-2012, 10:56 AM
HighLonesome
Its not always on low. It should cycle off completely from time to time. But likely something not worth thinking about.
Just got back from Napa. Got so freaking lucky finding JIC-37 fittings for my trans cooler project. The gal spent 45 minutes going through the fitting shelf until she found something that would work. Also found some hose clamps that are smooth and don't tear up the hose. Little jewels.
post #85 of 244 Old 07-28-2012, 11:19 AM
HighLonesome
top is clamp and Napa PN, handles 3/8" trans and power steering hose
other pic is left: female (unknown to me type) to stock 3/8" piping...other end is JIC-37 female, middle: JIC-37 male union, right: JIC-37 female to 3/8" barb
post #86 of 244 Old 07-28-2012, 11:22 AM Thread Starter
Cameleer
The e-fan comes on when the ac is on.
I have a 2 seep Lincoln mk 8 fan heading my way from eBay.
There’s a few people using these on 5.9 engines, thought I would check one out.
Most likely I would get a new single speed fan motor and hook a variable speed controller up to it.
This way you can set the temperature to something like 200 degrees and it will stay there with the fan just going faster or slower as needed.
It would be nice never seeing the temperature going over 200.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #87 of 244 Old 07-28-2012, 12:50 PM
HighLonesome
Looking forward to hearing about the Lincoln fan and your new rad!
Finally got the cooler plumbed..
post #88 of 244 Old 07-28-2012, 02:08 PM
Proph2010
1994 ZJ
Looks good man; you really gutted the front to get that thing in; I went a simpler route and just used those round zip ties and went through the fins on the condenser.
Proph2010 is offline
post #89 of 244 Old 07-28-2012, 02:42 PM
HighLonesome
thanks
I won't have a condenser to attach things to and I never liked those zip ties.
I did a bunch of other stuff too. Redid the Kolak headlight harness. Removed the relays for my fog lights as I will be going back to the stock harness since the LED fogs I got only draw 14 watts. Removed the fan controller and all wiring. Its amazing at how much electrical stuff is laying on my bench now! It feels good and simple.
I didn't like the harsh bend on the one hose so I redid it and added some loom...
post #90 of 244 Old 07-28-2012, 02:52 PM
HighLonesome
got the dash mat in! this will cut reflected heat and keep us cooler
cooling systems , desert , radiator , transmission
cooling systems LordHobbit ZJ Grand Cherokee Forum 2 03-01-2010 10:42 AM
Continued WJ power steering/cooling fan issue... 780406jeeper ZJ Grand Cherokee Forum 2 07-24-2009 08:26 PM
few questions. calling knowledge on magnet mount cb's, cooling systems, windows, ect fivespeedsteed ZJ Grand Cherokee Forum 19 04-15-2008 10:10 AM
WJ Power Steering Fluid Radiator Enhancement nedsud ZJ Grand Cherokee Forum 33 06-28-2006 11:55 PM
How are cooling systems flushed at dealerships? ChesterWilliams ZJ Grand Cherokee Forum 7 03-22-2005 07:58 AM
