Best Desert Cooling Systems, Radiator, Transmission, Power Steering - Page 3 - JeepForum.com
 3Likes
post #31 of 244 Old 07-13-2012, 12:15 PM
PolkaPower
Originally Posted by Proph2010 View Post
That's s good point, I bought the best trams cooler that advanced auto sold, it's a heavy duty towing cooler so I'd imagine it would be fine standalone then as well, I'm about to replace the condenser so I'll go ahead and eliminate the radiator from the trans cooling equation!
I think my Hayden is rated for 23,000lbs class C motor home. I might take it out and get a smaller fin and plate cooler though.
PolkaPower is offline
post #32 of 244 Old 07-13-2012, 12:22 PM
jtackerman28
I run just the aftermarket trans cooler. Because I bought a high capacity, for towing 12000#, and yes the radiator will just warm it back up if you plumb the cooled before the radiator, and may cool it too much in the winter if after the radiator
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #33 of 244 Old 07-13-2012, 12:24 PM
jtackerman28
Originally Posted by PolkaPower
I think my Hayden is rated for 23,000lbs which is RV. I might take it out and get a smaller fin and plate cooler though.
That's what I'm running, its smaller and cools better definitely worth the extra $
post #34 of 244 Old 07-13-2012, 01:13 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Can one of you guys explain this to me... Is is bad in the summer because the abient heat from the trans fluid adds heat the the engine coolant your trying to cool down? Is the auxarilary trans cooler capable of just cooling the trans? If thats the case whats the point in hooking it back up in the winter?
In the summer, the cooler in the radiator adds warmth when not necessary. The warmth comes from the engine coolant warming the entire radiator. A good aux cooler will do the job easily alone. The point of reconnecting is in the winter, the trans may never get up to operating temp. That can cause condensation to build up inside the trans.
HighLonesome is offline
post #35 of 244 Old 07-13-2012, 02:09 PM
Proph2010
1994 ZJ
Ahhh I see, that makes sense.
Proph2010 is offline
post #36 of 244 Old 07-13-2012, 02:29 PM
PolkaPower
Would you be able to tell if the trans fluid wasn't warm enough? Like would the OD light come on or it won't shift?
post #37 of 244 Old 07-13-2012, 03:46 PM
HighLonesome
I don't think so. I have a gauge with the sender in the pan.
post #38 of 244 Old 07-13-2012, 04:11 PM
jtackerman28
What's a good range?
post #39 of 244 Old 07-13-2012, 04:21 PM
HighLonesome
Without googling it , I think you need to get up to 160 or so to burn off the condensation. So running at 170-190 would be nice.
post #40 of 244 Old 07-13-2012, 04:27 PM
jtackerman28
Ok is putting an inline gauge before the cooler do the same thing as in pan one?
post #41 of 244 Old 07-13-2012, 05:46 PM
PolkaPower
I think it gives you a better indication of the health of your oil and you know if it's going to over heat. The hot line is the hottest the oil gets coming out of the converter. If that gets up towards 300* then you have a problem because the oil sheers(turns to varnish) at those temps and will no longer protect the clutches so it's time to change your trans oil. Plus you know that if the oil gets that hot at the converter then inside the transmission is well on it's way to overheating. The trans OD light will come on when the trans gets to 260* and the oil will boil out of the top of the trans shortly after that. The temps in the hot line are usually 30-40* hotter than inside the trans and will heat up and cool off rapidly during different driving conditions.
The temps in the pan are a mix of cool oil from the return and pan oil. It's not really an accurate reflection of whats going on after the pickup line inside the trans. If temps get to 260* in the pan then it's already to late because the temps inside the tranny will already be much higher.
post #42 of 244 Old 07-13-2012, 09:31 PM
HighLonesome
Great info. I can say my trans oil is red and clear after 2 years. I keep a wary eye on it. I may never change it again.
post #43 of 244 Old 07-13-2012, 09:39 PM
PolkaPower
I ended up emailing my buddy who works on the NASCAR circuit and he said that's where the pros run there senders so they can see if they are about to ruins a trans.
The only thing I can't stand is watching it heat up and cool off all the time. It makin' me crazy!
post #44 of 244 Old 07-13-2012, 10:13 PM Thread Starter
Cameleer
When talking to the guy at Ron Davis Radiators, I asked about using a 180 thermostat and he explained to me why not to use it and how the cooling system works.
Then when I asked about adding a external trans cooler to it, he said it was not needed, and not advised with this radiator.
Talked about water pumps, radiator corrosion, electrolysis, the proper coolant to use, PS cooling, and the Griffin Radiators vs the Ron Davis Radiators.
I learned a lot, have many more questions, and will be talking to them a few more times.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #45 of 244 Old 07-13-2012, 10:16 PM
HighLonesome
I'm all ears.
cooling systems , desert , radiator , transmission
cooling systems LordHobbit ZJ Grand Cherokee Forum 2 03-01-2010 09:42 AM
Continued WJ power steering/cooling fan issue... 780406jeeper ZJ Grand Cherokee Forum 2 07-24-2009 07:26 PM
few questions. calling knowledge on magnet mount cb's, cooling systems, windows, ect fivespeedsteed ZJ Grand Cherokee Forum 19 04-15-2008 09:10 AM
WJ Power Steering Fluid Radiator Enhancement nedsud ZJ Grand Cherokee Forum 33 06-28-2006 10:55 PM
How are cooling systems flushed at dealerships? ChesterWilliams ZJ Grand Cherokee Forum 7 03-22-2005 06:58 AM
