Best Desert Cooling Systems, Radiator, Transmission, Power Steering - Page 13 - JeepForum.com
 3Likes
post #181 of 244 Old 08-17-2012, 01:50 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The difference between the 5.9 efan/shroud and the 5.2 shroud is the 2 mounts under the radiator cover. When I did my efan I had to cut them I recall. The efan/shroud doesn't need the brackets for the 5.2 shroud, it has it's own integral brackets.
HighLonesome is online now
post #182 of 244 Old 08-17-2012, 01:53 PM
ilive4cars0122
I thought the efan clipped into the square holes on the tabs that protrude from the bottom of the rad.
ilive4cars0122 is offline
post #183 of 244 Old 08-17-2012, 01:58 PM
PolkaPower
They are integral !
PolkaPower is online now
post #184 of 244 Old 08-17-2012, 02:01 PM
HighLonesome
Right, the same as the 5.2 shroud does.
I think, somebody with a niner back me up here.
post #185 of 244 Old 08-17-2012, 02:03 PM
ilive4cars0122
Sorry I'm a bit confused I thought you just said they were different. Maybe I'm reading too fast
post #186 of 244 Old 08-17-2012, 02:05 PM
PolkaPower
The fan shroud has two clips at the bottom that slide into the radiator housing then bolts on the top.
post #187 of 244 Old 08-17-2012, 02:06 PM
HighLonesome
The bottom of the shroud has two prongs that slip into the slots on the bottom of the radiator. The top of the shroud has two brackets that connect to the mounts on top of the radiator.
So the top mounts differently between 5.2 shroud and 5.9 efan/shroud. The 5.2 brackets are part of the mounts and 5.9 brackets are part of the shroud. What I am wondering is if the lower tabs on the radiator are different between radiators. I don't think so.
post #188 of 244 Old 08-17-2012, 02:25 PM
PolkaPower
The rad I got from rock auto didn't have a spot for the e fan "prongs". I zip tied the hell out of it though. It's a work of art.
post #189 of 244 Old 08-17-2012, 07:30 PM
ilive4cars0122
I think I know what you mean now. Didn't know you meant the top brackets before. Either way I want that silla. Might have to call silla themselves and get a price. Hope it's not too absurd. On their website I also see a two row all aluminum that says available soon.
post #190 of 244 Old 08-18-2012, 07:19 AM
gothchick
Informative thread. My trans cooler is plumbed after the rad warmer/cooler and temp sending unit plumbed in the outgoing trans line. Sits around 200-205 on hill climbs. 180ish on the freeway. Think a Silla rad may be in my future.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #191 of 244 Old 08-18-2012, 09:23 AM
PolkaPower
Whats the temp outside?
post #192 of 244 Old 08-19-2012, 08:15 AM
HighLonesome
Here's what I'm talking about with the fan and shroud mounting. You can see where I cut the bracket off. Crappy uneven cut, can't miss it. The niner efan has the brackets attached to the shroud so the 5.2 brackets are just in the way.
post #193 of 244 Old 08-19-2012, 08:20 AM
HighLonesome
The trans cooler fan came in. I started the project even tho the temp switch won't be here til Tuesday. I hooked the fan up to a 12vdc power supply and I was amazed at how much air this little fan moves. Out of pure luck and nothing I planned , I'm able to pull the trans cooler up and away without removing too much. Grill, fan, shroud, and radiator cover so far.
A tip for removing the fan and shroud: once you get the fan clutch unbolted from the water pump without mangling your radiator, remove the radiator cover and move the radiator forward. The fan and clutch will come right out the top. Then you can pull the shroud up.
post #194 of 244 Old 08-19-2012, 09:52 AM
jtackerman28
to save the radiator I undue both then before pulling them out slide a piece of cardboard between radiator and the shroud
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #195 of 244 Old 08-19-2012, 10:09 AM
PolkaPower
So that 30,000 GVW cooler has kept my trans oil temp at around 150*. After about an hour or more of driving it warms up to 170*- 180*.
98GCLimited likes this.
cooling systems , desert , radiator , transmission
cooling systems LordHobbit ZJ Grand Cherokee Forum 2 03-01-2010 09:42 AM
Continued WJ power steering/cooling fan issue... 780406jeeper ZJ Grand Cherokee Forum 2 07-24-2009 07:26 PM
few questions. calling knowledge on magnet mount cb's, cooling systems, windows, ect fivespeedsteed ZJ Grand Cherokee Forum 19 04-15-2008 09:10 AM
WJ Power Steering Fluid Radiator Enhancement nedsud ZJ Grand Cherokee Forum 33 06-28-2006 10:55 PM
How are cooling systems flushed at dealerships? ChesterWilliams ZJ Grand Cherokee Forum 7 03-22-2005 06:58 AM
