Best Desert Cooling Systems, Radiator, Transmission, Power Steering - Page 11 - JeepForum.com
 3Likes
post #151 of 244 Old 08-14-2012, 10:42 PM
PolkaPower
I'm not so sure about that. they took away the stock aux cooler in the 5.9. I overheated the trans in 36* weather on a mountain trail. It's obviously not made for that. As long as it warms up enough for the overdrive to operate then it's warm enough. If it's to cold, I have heard the OD won't work. The thing with the 5.9+ 46RE is that it's a one year limited production. In the dodge trucks there are plentiful. There is an abundance of info about the 5.9 46RE combo on the Dodge forum.
I'm going to run it this way for a bit and see what temps I get on the trail slow moving in 100+ weather.
PolkaPower is offline
post #152 of 244 Old 08-14-2012, 11:27 PM Thread Starter
Cameleer
Basically it let's the trans fluid use the engine coolant thermostat so they don't have to put one in the trans fluid circuit.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #153 of 244 Old 08-15-2012, 10:24 AM
PolkaPower
First trip this morning at around 80* the trans didn't shift into OD until about 1/4 mile down the road. After that it shifted normally. This was well before the engine temp was near operating temperature. So the trans warms up a lot sooner than the motor which means that the radiator doesn't really help warm the trans up.
After my two mile trip the oil temp coming out of the TC was 155*. I probably won't mess with it until winter and see if it takes longer to reach operating temps.
post #154 of 244 Old 08-15-2012, 11:16 AM
ajmorell
ajmorell's Avatar
HighLonesome, I'm running the same radiator as you. I didn't read every thing in this thread, but is the rest of your cooling system otherwise stock? With the AC on my temps climb up to the tick past 210 when ambient is 80+, sometimes even just a bit past that. I'm not sure what the problem is. My entire cooling system is new. Flowkooler water pump, Silla radiator, stant superstat. Everything was completely redone when I put in my rebuilt 4.0 ~25k miles ago. Part of me wonders if between the single core radiator and the flowkooler the fluid doesn't have enough time to cool.
Also where in NM are you at?
ajmorell is offline
post #155 of 244 Old 08-15-2012, 11:40 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I'm in Abq
Mine climbed to 211 with no AC. Even the condenser is removed for more flow. That was climbing La Bahada going north. I'm going to have to live with it for 3 or 4 months a year.
HighLonesome is offline
post #156 of 244 Old 08-15-2012, 11:42 AM
PolkaPower
What kind of mix are you running? I am using around 15-20% antifreeze and the rest is water with a bottle of water wetter. When I flush it again I think I am going to only use 10% antifreeze.
post #157 of 244 Old 08-15-2012, 11:58 AM
HighLonesome
50-50
does it make that much difference?
it went down to -15 here a couple years ago, very rare and unusual but it can happen
post #158 of 244 Old 08-15-2012, 11:58 AM
ajmorell
ajmorell's Avatar
I don't remember exactly, but I think I'm running 60/40 coolant to water. I could go a little more in favor of water, maybe 50/50 or even 60/40 the other way but contrary to popular belief the winters can get pretty damn cold here.
ajmorell is offline
post #159 of 244 Old 08-15-2012, 01:05 PM
PolkaPower
Originally Posted by HighLonesome View Post
50-50
I think it made a difference with mine.
post #160 of 244 Old 08-15-2012, 01:24 PM
ajmorell
ajmorell's Avatar
I might try a flush & fill to see if it helps with the issue. I will probably go 40/60 coolant/water. I am going to give the Amsoil coolant a try and maybe throw in some of their Dominator coolant boost. They claim it's about twice as effective as water wetter.
ajmorell is offline
post #161 of 244 Old 08-15-2012, 01:27 PM
PolkaPower
Read about the dominator before you put it in because with the water wetter, the less antifreeze you add, the more effective it is. A lot of the guys around here only run water and water wetter in their off road vehicles. A few do the same with their cars.
post #162 of 244 Old 08-15-2012, 01:46 PM
ajmorell
ajmorell's Avatar
Dominator is the same way. It does better with 100% water than it does with a 50/50 mix, but it's still effective. They claim 19*F with straight water, and 6* with 50/50, I imagine that if I went 70/30 water/coolant it'd be somewhere in between, maybe 10*F or so.
ajmorell is offline
post #163 of 244 Old 08-15-2012, 01:51 PM
PolkaPower
I's so hot here I am temped to drink some.
post #164 of 244 Old 08-15-2012, 02:11 PM
HighLonesome
Looks like limeade.
I tell my wife I'm mixing up some kitty coolade (we have 2 cats)
post #165 of 244 Old 08-15-2012, 02:38 PM
PolkaPower
Looks like limeade.
lol I have a fat 15 year old cat. I used to threaten it all the time with euthanasia but since someone shot it and now it has diabetes I don't tease it as much. The .22 went through it's left arm and fragmented. The doc put a pin and plate in there and it's a bit shorter now but still runs around. You can feel the bullet frags under the skin.
cooling systems , desert , radiator , transmission
cooling systems LordHobbit ZJ Grand Cherokee Forum 2 03-01-2010 09:42 AM
Continued WJ power steering/cooling fan issue... 780406jeeper ZJ Grand Cherokee Forum 2 07-24-2009 07:26 PM
few questions. calling knowledge on magnet mount cb's, cooling systems, windows, ect fivespeedsteed ZJ Grand Cherokee Forum 19 04-15-2008 09:10 AM
WJ Power Steering Fluid Radiator Enhancement nedsud ZJ Grand Cherokee Forum 33 06-28-2006 10:55 PM
How are cooling systems flushed at dealerships? ChesterWilliams ZJ Grand Cherokee Forum 7 03-22-2005 06:58 AM
