> Models
> Jeep Grand Cherokee & Commander Forums
> ZJ Grand Cherokee Forum
Best Desert Cooling Systems, Radiator, Transmission, Power Steering
07-10-2012, 12:15 AM
#1
Looking at doing some cooling improvements for my 98 ZJ 5.9L where it will be able to handle some high temperatures in the desert when the going gets tough.
The cooling system will have to be extremely strong and reliable!
First off, between these two radiators below I'm thinking the Ron Davis would be best. Any other top quality brands to consider?
Ron Davis aluminum radiator
2 rows of 1 inch wide tubs
Griffin aluminum radiator
1 row of 1.5 inch tube
Next would be a good transmission cooler. The stock one works but a good after market one would be much better, along with adding a temperature gauge to it. What's a good larger cooler and how have other people mounted them?
Last, the power steering cooler. I've seen many different sizes and types. What types have other people used and where a good place to mount one?
Only those who will risk going too far
can possibly find out how far one can go.
07-10-2012, 01:22 AM
#2
Everyone and their mom loves their Griffin, go with the tried and true.
Also, I saw someone on MC do a huge tranny cooler from Summit, I'll try and find it.
As I'm sure you know, many people use the stock tranny cooler as a PS cooler, could always go that route after your radiator breaks the bank.
Will you be upgrading the water pump as well?
07-10-2012, 11:02 AM
#3
I have the FlowKooler water pump.
When at the junk yard the other day I looked a many PS coolers, some are a simple tube running in front of the radiator, some look more like a tranny cooler, and others have fins with huge tubes that hold more volume.
I don't like the Idea of using an old tranny cooler in front of the radiator, blocks too much air. Would rather have one off to the side or somewhere better.
My best bet may be going to the junk yard and pulling a few PS coolers, then go over to one of the ZJ's and see what will fit the best.
It would also be nice to have a better A/C condenser that would let more flow through.
I've seen coolers mounted under the hood with a fan, but I don't want to go this way.
Also mounting a larger cooler to the radiator is not good, need a good gap between them.
07-10-2012, 12:38 PM
#4
Here is a link to some discussion about tranny coolers:
http://mallcrawlin.com/forum/showthr...cooler-upgrade!
looks simple enough and definitely an upgrade.
Here is a link to using the tranny cooler as PS cooler, apparently is came this way from the factory in ZJ export V8s:
http://www.kevinsoffroad.com/techart...ingcooler.html
Also, I heard the Flowkoolers sometimes fail when the rivets on the impeller break. Do they still have this design? See I have been collecting stuff for a bullet-proof cooling system as well and I was leaning towards getting the Hesco water pump or just getting the Mopar.
07-10-2012, 12:42 PM
#5
As a side note, I am really surprised that I cant find another thread anywhere online where someone has tried to come up with a comprehensive plan for reliable cooling. Especially since these are heat factories.
07-10-2012, 12:50 PM
#6
PAVEMENT POUNDER
Auto tranny, get dual tranny coolers.
It's set up for it already.
00 XJ Sport(August 2012-Present) 4.0L - 156k, 6.5" IRO Adjustable Arm Lift, LMP Front Bumper, RC Double Sheer Track Bar, RC Quick Discos, Bilstein 5100s, IRO HnT SYE, Braided SS Brake Lines, 1" TC Drop, HiLift, Trimmed Fenders, Cherry Bomb, 33" BFGoodrich A/T on Eagle Alloy Recoils, Safari Snorkel, Safari Basket, 6x Hella 500, Autopal Harness + 80/100w H4 Bulbs
Thundercracker Build Thread
Built Not Bought #704
Past Jeeps:
93 ZJ Laredo(Jan 2011-April 2011) 5.2L - 98k, Stock - Totaled
96 ZJ Laredo(April 2011-August 2012) 4.0L - 138k, Cowl Intake, Rancho 9000 Series, 2" Spacers, 31" Baja MT Widetracks - Sold
Monstaliner: http://monstaliner.com/
Iron Rock Offroad: http://ironrockoffroad.com/
07-10-2012, 04:53 PM
#7
The Flowkooler water pump I got has the plate brazed on.
I was just at the junk yard looking around and thought about pulling another ZJ's transmission cooler for setting up a duel tranny cooling system. But they wanted $27 and the ones I found where not very good looking.
For a PS cooler I'm thinking of using something like these Derale coolers that come in different lengths: http://www.summitracing.com/parts/DER-13225/?rtype=10
07-11-2012, 12:56 PM
#8
Bump... Anyone else have cooling input?
07-11-2012, 02:50 PM
#9
Belief In All Things Jeep
If you have a secondary trans cooler, don't use the one in the radiator. At least in the summer anyway. I bypassed it and my trans temps are now 5-10 degrees lower and the engine seems to run slightly cooler.
07-11-2012, 03:06 PM
#10
I need to get off my lazy behind and route it just through aux cooler. From everything I have read this is a good idea.
"Thanks for the F shack, love Dirty Mike and the boys"
"What is best in life? "To crush your enemies, see them driven before you, and to hear the lamentations of the women."
07-11-2012, 03:43 PM
#11
I used a union so I can reconnect it for the winter, if necessary. The motor will still get to 215 climbing grades on a hot summer day. This concerns me. I've got the Mopar efan, hood vents and a Flowkooler pump. I never use the AC. I've been to 230 degrees trying to use it before I hit the panic button. Probably the cheap replacement radiator can't keep up with the transplanted niner or the Eddy headers make it hotter. :whoknows:
07-11-2012, 03:51 PM
#12
I have noticed in this heat that mine gets a tick over 210 with the ac on full blast city driving. It's hard to pin point why though since I put the aux cooler and cheaper new radiator in during the winter months. I do have a large Hayden HD cooler that takes up almost half of the condenser and I did not put the tar paper material from my old rad on the sides of the new one. It was falling apart anyway. My trans temp sender is in the hot line going into the rad and sometimes the temp gets to 215*ish for short periods of time when I'm just crawling. It goes back down fast though. After driving for about 2 hours it hovers around 200*. In the mornings it stays around 190*. I'm going to do a flush and fill using more water this time and re route the aux cooler. Got any pics of the union you set up? I may have to take a trip to Lowes.
07-11-2012, 04:37 PM
#13
Jeep Jedi Master
I never had an issue with this. However, I never drove on the sun either.... That being said, even with the crate 5.9, I ran the stock radiator without overheating.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
07-11-2012, 05:00 PM
#14
Hunter
It was 111* in the shade here the other day. About 118* in the sun. Probably 115* today.  Crawling around slow on a rocky rail really puts it to the test. I can't wait until August.
07-12-2012, 08:00 AM
#15
I'll snap one. I used some fittings I had laying around from replacement radiators. And I cut and flared the hardlines years ago so it is a fairly bastardized setup.
