-   -   Best Desert Cooling Systems, Radiator, Transmission, Power Steering (http://www.jeepforum.com/forum/f13/best-desert-cooling-systems-radiator-transmission-power-steering-1391222/)
Cameleer 07-10-2012 12:15 AM
Looking at doing some cooling improvements for my 98 ZJ 5.9L where it will be able to handle some high temperatures in the desert when the going gets tough.
The cooling system will have to be extremely strong and reliable!
First off, between these two radiators below I'm thinking the Ron Davis would be best. Any other top quality brands to consider?
Ron Davis aluminum radiator
2 rows of 1 inch wide tubs
Griffin aluminum radiator
1 row of 1.5 inch tube
Next would be a good transmission cooler. The stock one works but a good after market one would be much better, along with adding a temperature gauge to it. What's a good larger cooler and how have other people mounted them?
Last, the power steering cooler. I've seen many different sizes and types. What types have other people used and where a good place to mount one?
bananaslug 07-10-2012 01:22 AM
Everyone and their mom loves their Griffin, go with the tried and true.
Also, I saw someone on MC do a huge tranny cooler from Summit, I'll try and find it.
As I'm sure you know, many people use the stock tranny cooler as a PS cooler, could always go that route after your radiator breaks the bank.
Will you be upgrading the water pump as well?
Cameleer 07-10-2012 11:02 AM
I have the FlowKooler water pump.
When at the junk yard the other day I looked a many PS coolers, some are a simple tube running in front of the radiator, some look more like a tranny cooler, and others have fins with huge tubes that hold more volume.
I don't like the Idea of using an old tranny cooler in front of the radiator, blocks too much air. Would rather have one off to the side or somewhere better.
My best bet may be going to the junk yard and pulling a few PS coolers, then go over to one of the ZJ's and see what will fit the best.
It would also be nice to have a better A/C condenser that would let more flow through.
I've seen coolers mounted under the hood with a fan, but I don't want to go this way.
Also mounting a larger cooler to the radiator is not good, need a good gap between them.
bananaslug 07-10-2012 12:38 PM
Here is a link to some discussion about tranny coolers:
http://mallcrawlin.com/forum/showthr...cooler-upgrade!
looks simple enough and definitely an upgrade.
Here is a link to using the tranny cooler as PS cooler, apparently is came this way from the factory in ZJ export V8s:
http://www.kevinsoffroad.com/techart...ingcooler.html
Also, I heard the Flowkoolers sometimes fail when the rivets on the impeller break. Do they still have this design? See I have been collecting stuff for a bullet-proof cooling system as well and I was leaning towards getting the Hesco water pump or just getting the Mopar.
bananaslug 07-10-2012 12:42 PM
As a side note, I am really surprised that I cant find another thread anywhere online where someone has tried to come up with a comprehensive plan for reliable cooling. Especially since these are heat factories.
DNFJ 07-10-2012 12:50 PM
Auto tranny, get dual tranny coolers.
It's set up for it already.
Cameleer 07-10-2012 04:53 PM
The Flowkooler water pump I got has the plate brazed on.
I was just at the junk yard looking around and thought about pulling another ZJ's transmission cooler for setting up a duel tranny cooling system. But they wanted $27 and the ones I found where not very good looking.
For a PS cooler I'm thinking of using something like these Derale coolers that come in different lengths: http://www.summitracing.com/parts/DER-13225/?rtype=10
bananaslug 07-11-2012 12:56 PM
Bump... Anyone else have cooling input?
HighLonesome 07-11-2012 02:50 PM
If you have a secondary trans cooler, don't use the one in the radiator. At least in the summer anyway. I bypassed it and my trans temps are now 5-10 degrees lower and the engine seems to run slightly cooler.
PolkaPower 07-11-2012 03:06 PM
I need to get off my lazy behind and route it just through aux cooler. From everything I have read this is a good idea.
HighLonesome 07-11-2012 03:43 PM
I used a union so I can reconnect it for the winter, if necessary. The motor will still get to 215 climbing grades on a hot summer day. This concerns me. I've got the Mopar efan, hood vents and a Flowkooler pump. I never use the AC. I've been to 230 degrees trying to use it before I hit the panic button. Probably the cheap replacement radiator can't keep up with the transplanted niner or the Eddy headers make it hotter. :whoknows:
PolkaPower 07-11-2012 03:51 PM
I have noticed in this heat that mine gets a tick over 210 with the ac on full blast city driving. It's hard to pin point why though since I put the aux cooler and cheaper new radiator in during the winter months. I do have a large Hayden HD cooler that takes up almost half of the condenser and I did not put the tar paper material from my old rad on the sides of the new one. It was falling apart anyway. My trans temp sender is in the hot line going into the rad and sometimes the temp gets to 215*ish for short periods of time when I'm just crawling. It goes back down fast though. After driving for about 2 hours it hovers around 200*. In the mornings it stays around 190*. I'm going to do a flush and fill using more water this time and re route the aux cooler. Got any pics of the union you set up? I may have to take a trip to Lowes.
Texas ZJ1 07-11-2012 04:37 PM
I never had an issue with this. However, I never drove on the sun either.... That being said, even with the crate 5.9, I ran the stock radiator without overheating.
Hunter
PolkaPower 07-11-2012 05:00 PM
Hunter
It was 111* in the shade here the other day. About 118* in the sun. Probably 115* today.:laugh: Crawling around slow on a rocky rail really puts it to the test. I can't wait until August.
HighLonesome 07-12-2012 08:00 AM
I'll snap one. I used some fittings I had laying around from replacement radiators. And I cut and flared the hardlines years ago so it is a fairly bastardized setup.
The time now is 01:45 AM.
