best cold air intake system - JeepForum.com
post #1 of 18 Old 06-03-2012, 10:54 AM Thread Starter
razortec_hunter
Well i was about to order the K&N FIPK for my 5.9 but im hesitant to spend 250$ untill i ask you guys what you think, this forums been extremely helpful! Out of all the intake systems what do you think is going to be the best performance intake??
razortec_hunter is offline
post #2 of 18 Old 06-03-2012, 10:56 AM
DNFJ
Snorkel or make a cowl intake.
Any "cold air intake" that's still in the engine bay is actually just sucking up warm air.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #3 of 18 Old 06-03-2012, 10:59 AM Thread Starter
razortec_hunter
As a daily driver i dont really wanna be running a snorkel in the rain an such, and i dont really wanna mod my 5.9 hood. Atleast not right now...
post #4 of 18 Old 06-03-2012, 11:18 AM
stageninja
That Rigger Guy
stageninja's Avatar
This ? Seems to come up weekly. The stock box was designed for these Jeeps and for a daily driver I wouldn't spend the $$.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #5 of 18 Old 06-03-2012, 11:21 AM
WhiteOut
WhiteOut's Avatar
Useless unless you have the other mods to go with it, and a snorkel is money down the drain without a ton more work done.
WhiteOut is offline
post #6 of 18 Old 06-03-2012, 11:40 AM
JasonStebbins
Keep the intake stock. You could try running a K&N filter for the extra air flow. A throttle body spacer is relatively cheap and would help with air flow as well. Other than that and exhaust/ignition upgrades, the 4.0L does well how it is.
JasonStebbins is offline
post #7 of 18 Old 06-03-2012, 11:47 AM Thread Starter
razortec_hunter
Well ive got 3" exhaust to a magnaflow cat and flowmaster muffler so ive got flow through my exhaust, and i cant keep it stock cause its already got a cone filter from the guy before, but its old and only comes about a foot off the throttle body and catches ALLOT of heat. So i just wanna do a new system, and along with that im also getting a 52mm TB and spacer, so a cold air intake would be an appropriate upgrade i think? Im just wondering if k&n is THE one to get?
post #8 of 18 Old 06-03-2012, 11:49 AM
PolkaPower
This is the best cold air system and it was only about 30 bucks for the hat and tubing. http://www.jeepforum.com/forum/f13/d...5-9-a-1315001/
And it still filters dirt unlike the K&N. I would wait before you waste 300 bucks if you are unsure what to do. There are many better things you could put that money too other than a K&N.
PolkaPower is offline
post #9 of 18 Old 06-03-2012, 12:06 PM Thread Starter
razortec_hunter
This is whats on it now, bought the jeep this way..
post #10 of 18 Old 06-03-2012, 12:39 PM
Erbo1Kanerbo
haha that is sucking the heat straight from the headers and engine block man if this was my jeep i would go to advance auto right now and just buy some tubing and clamp it. get that cone as far from the engine as possible
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #11 of 18 Old 06-03-2012, 12:59 PM
vonericsen
Don't bother with one. Not with the cost.
I have one and it made a small performance difference, but that still isn't worth it.
It also doesn't seal well against the throttle body with out an additional spacer...after that I feel better about it but I still want to get rid of it and go with the stock box and durango air hat.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #12 of 18 Old 06-03-2012, 01:20 PM
JasonStebbins
By the way, that picture is a 5.2L and your profile says you have a 4.0L
Kanerbo is right, that is terrible placement for the cone.
Have you upgraded your ignition system already?
Champion copper plugs
Brass tipped distributor cap
New cap/rotor
The stock wires are 7mm I put a set of 8mm on mine.
post #13 of 18 Old 06-03-2012, 01:41 PM
PolkaPower
New cap/rotor
He just bought a 5.9.
post #14 of 18 Old 06-03-2012, 02:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
buy a stock box and a durango air hat when you go to the salvage yard.
or a ford windstar filter box, durango air hat, and some straight tubing and silicone reducers from autozone to run it to the grille.
knn is a total waste of money when MUCH better options are out there like those listed above.
ratmonkey is offline
post #15 of 18 Old 06-03-2012, 04:10 PM Thread Starter
razortec_hunter
New cap/rotor
Its a 5.9 motor, i just bought a 9er a couple days ago, haven't updated my profilee
