best catalytic converter for a decent price? - JeepForum.com
post #1 of 17 Old 05-07-2013, 04:28 PM Thread Starter
Bigdjs123
I have a magniflow high flow cat and after 2 and a half years its done. What is a good and cheaper replacement? I don't wanna soend more than $150 but if I have to to get one that will last more than 3 years ill spend a little more.
Bigdjs123 is offline
post #2 of 17 Old 05-07-2013, 04:39 PM
98ZJLTD
I bought my magnaflow high flow cat off amazon for $100 like a year ago, you might check that out.
98 ZJ Limited- NP231 swap, IRO 4.5 inch Springs, Hydro Shocks, IRO adjustable double shear track bar, JKS quick discos 33x12.50 Kumho Road Venture MT on 15x8 D windows with 3.75 inch BS
My build thread-
98ZJLTD is offline
post #3 of 17 Old 05-07-2013, 04:52 PM Thread Starter
Bigdjs123
I don't want another one. It didn't ladt as long as I thought it would. It was a waste. Thanks though
post #4 of 17 Old 05-07-2013, 05:00 PM
98ZJLTD
I hear ya. Either way once you find the cat you wanna get I would still suggest checking amazon. I found my flowmaster super 44 on there with free shipping for $20 or $30 less then what they wanted at any of the local parts stores on my area as well.
My build thread-
98ZJLTD is offline
post #5 of 17 Old 05-07-2013, 05:05 PM Thread Starter
Bigdjs123
Will do
post #6 of 17 Old 05-07-2013, 05:39 PM
KoreaZJ
1994 ZJ
What's wrong after only 2 years?
I have a Magnaflow Direct Fit from Amazon, nearly 2 years old, still looks like new.
KoreaZJ is offline
post #7 of 17 Old 05-07-2013, 05:41 PM Thread Starter
Bigdjs123
I looks new but its throwing me a code for bad catalyst effciency. And I just replaced the downsream o2 with an ntk
post #8 of 17 Old 05-07-2013, 05:42 PM
ShinyWJ
Maybe you should look for a Chrysler cat. My original one is still working after 245,000 miles. Just had emissions done last month.
ShinyWJ is offline
post #9 of 17 Old 05-07-2013, 05:56 PM Thread Starter
Bigdjs123
That's crazy because they had a recall on them lol. At least for 96s they did
post #10 of 17 Old 05-07-2013, 06:49 PM
KoreaZJ
1994 ZJ
No downstream sensor on my '94. Just needs to pass annual inspection.
My original cat still passed after 130K with the insides rattling around for a few years, which got annoying. Decided to give the neighborhood dogs a rest and replaced it.
KoreaZJ is offline
post #11 of 17 Old 05-07-2013, 07:29 PM
Kolak
Vendor
Kolak's Avatar
If you fried a converter after a year or two, you may have a sluggish O2 sensor or other mixture control issues. When did you last replace the O2 sensor?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #12 of 17 Old 05-07-2013, 07:40 PM Thread Starter
Bigdjs123
I replaced the rear about a month or 2 ago with an ntk. I haven't had a chance to replace the front yet
post #13 of 17 Old 05-07-2013, 07:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
yeah, you have other issues going on if you burnt one of those up that quickly.
ratmonkey is offline
post #14 of 17 Old 05-07-2013, 07:59 PM Thread Starter
Bigdjs123
How long should they last? Beside the upstream o2 what else could be causing it to go back that quick?
post #15 of 17 Old 05-07-2013, 08:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
burning oil, bad injectors, misfiring, low compression, running rich, exhaust leaks before the cat.
