Quantcast best brake pads and rotors? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > best brake pads and rotors?
Old 01-05-2009, 05:56 PM   #1
lsejlowe
my '02 Overland is rolling up on 98K and it's time for new brakes. It's essentially stock and I don't do much towing, but I would like to be able to tow a trailer if the need arises. I do some occasional offroading, so good wet/mud traction is a must. The rotors appear somewhat grooved, so I plan to replace pads and rotors on all 4 corners. After doing a fair bit of reading, I'm struggling with which brands to buy. I've heard good things about the ECB Greenstuff and Yellowstuff pads, but they seem like overkill for a stock application. However, I'm hesitant to go with the cheapo Autozone parts because I'd rather not cut any corners when it comes to brakes.
Right now I'm looking at a set of Brembo rotors ($110 for fronts, $106 for rears) and Hawk SUV pads ($74 for front set, $62 for rear set) on tirerack.com: tirerack brakes
I just spent $650 on new tires, so I'd rather spend less, but if this is the best route I'll just bite the bullet. Would a full set of Wagner rotors and pads be a bit cheaper without sacrificing quality?
Also, does anyone know the VIN break between Teves and Akebono calipers? WJjeeps says it was May 10th, 2002, but I'm not sure how to translate that to VIN. My serial number is 330018
I drive an American Car.
It's a lot better than those rice burners and strudel wagons.
-Artie, "The Larry Sander's Show"
lsejlowe is offline   Reply With Quote
Old 01-05-2009, 05:57 PM   #2
DothanJeep
EBC Green Stuff.
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline   Reply With Quote
Old 01-05-2009, 06:02 PM   #3
BlackShuck
You could save yourself the number trouble and just take a peek at your calipers. Akebono are more silver colored. Teves are supposed to be darker, though mine are more rusty colored than anything. If you see some ~1/16" wire thingers near the hub, = Teves. The Akebono don't have them, but rather a metal support flange kinda thing.
I saw some pictures once, I'll have to steal them and post them. EDIT:
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline   Reply With Quote
Old 01-05-2009, 06:17 PM   #4
99avant
I like my rotors from NAPA. They have a pretty good warranty, and napa is usually real good about taking stuff back.
Pretty cheap too.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline   Reply With Quote
Old 01-05-2009, 06:18 PM   #5
lsejlowe
awesome, thanks for the pics. They're definitely Akebono's (bottom pic). From the reading I've done so far it seems like most people have gotten by pretty well with the cheaper Autozone stuff. For a typical street driving are those good enough? I'd hate to spend the $$ on a higher quality set or rotors and then end up warping them or something...
Care to elaborate on the ECB Greens?
Old 01-05-2009, 06:25 PM   #6
Kolak
Vendor
You might want to check out the sale on Stillen rotors and pads I was running over at the vendor forum:
http://www.jeepforum.com/forum/f43/stillen-rotors-pads-end-year-sale-654094/
I can still get you in on the deal if you are interested. It's a very worthwhile upgrade.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote
Old 01-05-2009, 06:27 PM   #7
ZJPunk98
Addicted to my jeep
ZJPunk98's Avatar
Originally Posted by dothanjeep View Post
EBC Green Stuff.
Definitely EBC green or yellow stuff. I have the yellow all around and the EBC slotted and dimpled rotors in the front and ebc blanks in the rear
Go EBC!!!
Erik
98 ZJ 5.2L JGC Limited
185K still running great
ZJPunk98 is offline   Reply With Quote
Old 01-05-2009, 06:31 PM   #8
BlackShuck
We must not have been reading the same material.
True though that some have been happy with them, but these same people that were happy with them didn't mind utilizing the lifetime warranty that they came with every 30K miles.
Just seems like a pain to have to return them every 3 years, not to mention the labor involved. Since you have the akebono you're a step up on me, but I'd suggest at least the Brembos. They have proved successful for some here.
Utah Jeep Crew #8
Old 01-05-2009, 06:39 PM   #9
99avant
Autozone quality != Napa Quality
I am more than happy to get 30k out of brakes...
Old 01-05-2009, 06:49 PM   #10
BlackShuck
This is what I'm referring to. I've been dealing with brake pulsing for over 45,000 miles now. I'll be installing stillen rotors in the near future and they better last at least 100,000 miles. For me, time is money. And I'd rather not be installing new rotors every few years.
Disclaimer: Nothing against avant, everyone has their own style and luck with brakes. (just illustrating my prior statement)
Utah Jeep Crew #8
Old 01-05-2009, 06:54 PM   #11
99avant
Exactly, nothing wrong with either path.
Make sure it really is your brakes pulsating before you drop that serious coin, but Im sure you have if you have had 45K to think about it.
Old 01-05-2009, 07:01 PM   #12
BlackShuck
I get some MAD steering shimmy when I apply brakes in the 45+ mph zone. And even when I'm slowing to a red light, if I put slight constant pressure on the brakes and roll forward.....The Jeep will roll a bit, then I can feel it kinda grab, then it will roll easier again, and kinda grab again. Seems as though with each rotation of the rotor it will grab harder in certain places than other. Is this warpage? Or something completely different and more serious?
Utah Jeep Crew #8
Old 01-05-2009, 08:03 PM   #13
99avant
Could be your calipers. One of mine was frozen up and causing some wicked shimmy under heavy braking. A replacement and new fluid fixed that right up.
But we are getting off topic here.
I really don't believe that drilled or slotted rotors are necessary.. A street jeep's brakes will not be getting that hot to need that. Any reduction in surface area is a reduction in the effective surface.
Old 01-05-2009, 08:18 PM   #14
Kolak
Vendor
That runs counter to my experience with our Jeeps. Drilled rotors, when properly done, definitely increase cooling and reduce stopping distaneces. The DOT did a very comprehensive study of drilled rotors a couple year ago by the way, confirming that they shorten stopping distances, even for the very first hard stop.
The Stillens have been an exemplary product over my 12 years of being their vendor, and 15 years in using them on my Jeeps. If you want improved safety and performance, they are well worth the investment.
Old 01-05-2009, 10:13 PM   #15
ZJPunk98
Addicted to my jeep
ZJPunk98's Avatar
EBC!!!
sorry.. had to say that. I like ebc
www.perfectbrakes.com A guy Joe owns/runs the company. I have ebc on my jeep and jetta. He has the best prices I could find.
Erik
Glock Forum
