Bent Control Arm, what to expect, plus rattle sound - JeepForum.com
post #1 of 4 Old 06-25-2013, 02:02 PM Thread Starter
lil_joe
OK, so I bent my passenger side lower control arm the other day wheeling, I don't have any pics, but imagine the stock control arm "squeezed" together. I have yet to notice any driving issues, what could go wrong if I were to drive it like this for a 100 miles or so?
Second issue: there is a rattling sound coming from under my left foot while driving, hitting mild bumps, it has been doing that since I took ownership, I have replaced all CA bushings, to no relief. What is the possibility the sound is a failing CV?
Thanks,
Mike
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #2 of 4 Old 06-25-2013, 03:04 PM
speedbucket
Failing CV /joint or transfer case output bearings, check your case fluid to rule out running it dry. Post a pic of the control arm. Depending on the severity and upper or lower arm it will certainly have adverse effects
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #3 of 4 Old 06-25-2013, 03:37 PM Thread Starter
lil_joe
Working on pics, I recently swapped my t-case, so rules that out, any test I could do to check the CV?
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #4 of 4 Old 06-25-2013, 03:55 PM Thread Starter
lil_joe
all views from the rear
Thanks for the help,
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
