Bent ARB Bumper - Page 2 - JeepForum.com
post #16 of 32 Old 08-31-2012, 11:27 AM
mbelden
Originally Posted by DickDickle View Post
it does not even look like it was mounted center. it looks like its way off to the passenger side, maybe its just me
I saw that as well...I was thinking it's because the headlight was gone and the void made the appearence of it being mounted more towards that passenger side...that being said given the impact point, I wouldn't be suprised if it did shift that way.
mbelden is offline
post #17 of 32 Old 08-31-2012, 11:32 AM
ZeJokee
Any chance if you know if that ZJ is a 5speed? I knew a guy in NC that had a 4.0 ZJ with a 5 speed swap and a arb bumper.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #18 of 32 Old 08-31-2012, 12:28 PM
mbelden
He told me it's an auto...
mbelden is offline
post #19 of 32 Old 08-31-2012, 02:38 PM
DickDickle
I saw that the head light is missing but that was not a factor in my decision that it isn't mounted right look at where the center of the opening for the condensor is and then look to the left and the right it def does not look like its centered on the jeep
DickDickle is offline
post #20 of 32 Old 08-31-2012, 03:12 PM
airwolf9090
I think its just the way he took the photo because you can see hes not standing centered hes standing to the driver side alittle bit
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #21 of 32 Old 08-31-2012, 03:49 PM
JrMechanic
That bumper is junk unless you cut out the damaged side and completely refab it. $400 for a bent up ARB and "custom" roof rack sounds like an awful deal.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #22 of 32 Old 08-31-2012, 05:32 PM
mbelden
The purpose for this bumper is to have a place to mount a winch. Seller is going to install the bumper for me...should I talk him down? Do you think this will still serve that purpose? Sorry for all the ?'s...
mbelden is offline
post #23 of 32 Old 08-31-2012, 05:50 PM
jtackerman28
Would have to see the mounts
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #24 of 32 Old 08-31-2012, 05:53 PM
Myusername1674
Def check it in person before promising to buy it. Any pics of the rack? Im curious.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #25 of 32 Old 08-31-2012, 06:34 PM
mbelden
I'm not going to buy it without checking it out. Pic attached...
mbelden is offline
post #26 of 32 Old 09-01-2012, 08:52 AM
DickDickle
Not worth 400 for either imo
post #27 of 32 Old 09-01-2012, 08:56 AM
PolkaPower
I also wouldn't want some guy I just met installing parts on my Jeep. A professional shop is one thing but it's just my opinion that other people don't hold the same about of interest as if it were their own.
PolkaPower is online now
post #28 of 32 Old 09-01-2012, 10:11 AM
Erbo1Kanerbo
that roof rack looks terrible and that arb is in terrible shape. I got my arb bumper off craigslist for $300 and before that there were two others on craigslist in good condition for $500
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #29 of 32 Old 09-01-2012, 12:40 PM
ZJ_flexxxer
1994 ZJ
first of all, pic is not taken from the center of the vehicle. you can clearly see more of the passenger inner fender in the pic than the driver inner fender. use some common sense ppl.
second that roof rack is not the greatest looking thing i've ever seen. the bumper is repairable with some time, hard work, and patience. but imo not worth $400 for both. personally i would try to get the bumper only for about $250. but the most important thing is that it's YOUR jeep, build it the way YOU want it.
(on a side note. i think i recall someone on JF sending a bent ARB back in for a new one. might be worth looking into)
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
ZJ_flexxxer is offline
post #30 of 32 Old 09-01-2012, 08:20 PM
fljeepney
I seen an ARB on a Trooper at the JY today.Don't know what they hit,but the bumper was not worth taking off.It was smashed in that bad.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
arb , bent , bull bar , zj
When an axle is bent, is the axle shafts, or the tube that is bent ? Candymancan ZJ Grand Cherokee Forum 7 04-08-2011 03:41 PM
tie rod bar bent? please help frankenjeep ZJ Grand Cherokee Forum 9 07-22-2010 09:46 PM
Tie-rod bent alexsious ZJ Grand Cherokee Forum 19 01-10-2009 02:14 PM
Bent Oil Pan - 4.0L UofOJeeper ZJ Grand Cherokee Forum 11 02-19-2008 07:48 PM
Bent Tie Rod?? greasefingers ZJ Grand Cherokee Forum 16 03-31-2005 09:00 PM
