Belts shake when A/C is on - JeepForum.com
post #1 of 5 Old 09-11-2004, 04:16 PM Thread Starter
LBX2G
Well just like the title says. See I have a Jeep Grand Cherokee ( xJ I thing????). It is an Inline 6. But when i cut the A/C on the egine belts tend to shake. And first when I looked at it I thought it was the fan causeing it to shake. Cus the belt only shake in a certian spot. Like right after the anlternator pulley going to the main one that is connect to the engine. THe belts shakes at about 1.5 inches side to side. Now all this stops when I turn the A/C off. I runs smooth and the car does not shake either. BUt when i turn it back on it start again............
oh also I noticed the cluch on the compressor seems a litttle lose. It wobbles up and down a lil less than .25 inches. Is that the problem?????????????
I mean is this something to worry about or am i just being anal....
Thnx in advance.
LBX2G is offline
post #2 of 5 Old 09-11-2004, 08:20 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Thnx in advance.
You don't say what year or engine, the 93-98 grands are ZJ and the 99-04 are WJ, XJ is the Cherokee (not grand).
I'm no expert but that sounds like a bad compressor bearing - you probably need to get it to a reputable shop or two to have it checked. I think that any wiggle in the pully is a bad thing.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 5 Old 09-11-2004, 08:54 PM Thread Starter
LBX2G
welll it is not wiggle it jiggle's up and down a lil bit. The bolt does seem a lil lose. And it is an 95 ZJ........
but kinda bobbles a lil less than .25 inches....
thnx in advance
LBX2G is offline
post #4 of 5 Old 09-11-2004, 09:03 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Tighten that center bolt or it will ruin your compressor.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 5 Old 09-12-2004, 12:59 AM Thread Starter
LBX2G
ok will do
LBX2G is offline
ZJ with !bad! shake! Rednecksusa ZJ Grand Cherokee Forum 7 05-05-2009 07:28 PM
Shake!! irate808 ZJ Grand Cherokee Forum 3 09-02-2007 12:13 PM
95 ZK Shake? Lawdog1 ZJ Grand Cherokee Forum 6 04-01-2007 12:08 PM
When you Wobble, wobble, I'll Shake it, Shake it. ZJ_COWBOY ZJ Grand Cherokee Forum 2 04-07-2005 08:40 AM
New belts? JeepingOverYou ZJ Grand Cherokee Forum 2 03-20-2005 06:48 PM
