Belt squeels when AC is on - JeepForum.com
post #1 of 13 Old 07-24-2011, 02:12 PM Thread Starter
steve L.
So it seems that whenever I turn on my AC the belt starts to squeak really bad. I assume I need to tension the belt? If so, how do I do that exactly?
97' ZJ Laredo, I6, NP242
A Little Taste of Jersey Wheelin Of A 1997 & 1998 Jeep Grand Cherokee's For Your Enjoyment.
steve L. is offline
post #2 of 13 Old 07-24-2011, 07:29 PM
classicmetalman
Sure it's your belt and not one of your pullies?
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #3 of 13 Old 07-24-2011, 08:12 PM
TheHalfWit
I'd check the deflection of the belt, and how loose it feels. The adjustment method is different from my 95 but I dug up a pic on adjusting the manual 96-98 I6
http://www.jeepforum.com/forum/f13/z...2/#post8759648
(hope thats the right diagram, the 93-95's are a lot more fun to do. )
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #4 of 13 Old 07-25-2011, 12:24 AM
dougreuter
I just had to replace mine because it did that, even if the belt is stripped just a little bit it will make that sound
dougreuter is offline
post #5 of 13 Old 07-25-2011, 12:46 AM
Candymancan
Mine did the same thing, when it started getting warm outside i turned the A/C on and then the belt started to squeel. Then went away but then a week later it just got so bad the noise was unbearable. Replaced the belt with a new one and it works like a dream now. Been working fine for a few months now. Make sure you clean and inspect the pully's for bad bearings and wobble.
Candymancan is offline
post #6 of 13 Old 07-25-2011, 02:02 AM
Bale
My serpentine belt sometimes squeals for a few seconds after startup. Can't see why it squeals some times, and most times not
A question: The belt has lots of tiny transverse cracks on the outside. Time for replacement, or is this normal?
Thanks in advance.
1998 ZG (ZJ) Grand Cherokee Ltd, 4L 4x4
Bale is offline
post #7 of 13 Old 07-25-2011, 06:27 AM
Boodyrider
Time for replacement.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #8 of 13 Old 07-25-2011, 07:29 PM Thread Starter
steve L.
I don't think it's the belt. It's not in bad shape. It only does it when I first turn on the AC. Then once the engine warms up it goes away.
steve L. is offline
post #9 of 13 Old 07-25-2011, 07:49 PM
Candymancan
My old belt looked ok too, but like i said after i replaced it is was fine. Its only $30
post #10 of 13 Old 07-25-2011, 08:14 PM
CrazyMacaw
If you're sure the belt is ok and tensioned correctly then it could be the compressor showing signs of wear or maybe it's pulley is glazed.
CrazyMacaw is offline
post #11 of 13 Old 07-25-2011, 08:22 PM Thread Starter
steve L.
how do I know if it is tensioned correctly?
steve L. is offline
post #12 of 13 Old 07-26-2011, 12:09 AM
CrazyMacaw
Well, if you're really good you just grab the belt with one hand, stick your tongue out the left side of your mouth and with the other hand scratch your privates and proclaim "feels pretty good to me"
Me personally, I prefer to measure the belt tension between the idler pulley and the p/s pulley with a belt tension gauge. Not enough tension and the belt slips, too much tension and you could cause damage to the bearings of the engine's externals.
A new belt should have between 180lbs - 200lbs of tension.
A used belt should have between 140lbs - 160lbs of tension.
Gates makes an inexpensive tool called a Krikit II for checking Ribbed V /serpentine belts they're about $20.
post #13 of 13 Old 07-26-2011, 05:33 AM
melk
Just installed a new Gates belt on my 4.0 and it made a world of difference. Engine runs tight and strong, not loose and sloppy like it used to. Paid $44 local.
melk is offline
Fan belt help! j_ag1124 ZJ Grand Cherokee Forum 1 06-17-2011 11:58 PM
what V belt do I need groomvroom ZJ Grand Cherokee Forum 3 07-22-2009 11:30 AM
Water Pump and Belt/Belt Tensioner pilitusf ZJ Grand Cherokee Forum 2 07-04-2009 05:01 AM
Bad Belt? Yardman Harry ZJ Grand Cherokee Forum 3 10-22-2006 09:06 PM
That belt is really pis..... ZJ_COWBOY ZJ Grand Cherokee Forum 3 12-16-2004 03:31 PM
