Belt squealing - JeepForum.com
post #1 of 22 Old 11-27-2010, 11:23 AM Thread Starter
andrayder
Belt squealing
So my serpentine belt has started squealing really badly lately, I have changed my tensioner, my idler, and my belt and I have a new water pump waiting to go in but now I'm not even sure if that's what is causing it. I can't stand the sound and its friggin driving me crazy, any ideas on whats causing the noise?
andrayder is offline
post #2 of 22 Old 11-27-2010, 11:46 AM
melk
tighten it more
melk is offline
post #3 of 22 Old 11-27-2010, 12:07 PM Thread Starter
andrayder
YouTube - Belt squeal
Heres a video so that you can actually hear the noise. It is also much worse when I am moving.
post #4 of 22 Old 11-27-2010, 12:07 PM Thread Starter
andrayder
Originally Posted by melk View Post
tighten it more
How?
post #5 of 22 Old 11-27-2010, 12:14 PM
JasonStebbins
Originally Posted by andrayder View Post
How?
Loosen the pulley that is all the way down on the right, then there's a very long bolt (about a foot long) behind it that tightens the belt. After you get it where you want it, re-tighten the pulley.
Poop
JasonStebbins is offline
post #6 of 22 Old 11-27-2010, 12:19 PM
newfieZJ
Can tighten the V8's belt .
I know you have a new belt , but , it sounds like my old belt to be honest . I'd try squirting some WD diectly to the belt , takes just a little . If the noise goes away , you got a bad belt . If not , maybe it's from the AC compressor .
Observe the engine cooling fan and make sure the w/pump bearing isn't wobbling the fan . My buddy is fixing that issue as we type , lol .
newfieZJ is offline
post #7 of 22 Old 11-27-2010, 12:48 PM Thread Starter
andrayder
I sprayed some wd 40 on the belt and the squeal did stop, what brands does everyone recommend this ones a cheap durolast.
post #8 of 22 Old 11-27-2010, 12:51 PM
ezab
I used to only buy the Goodyear Gatorback Belts but nobody locally carries them anymore. So now I just buy the most expensive belt out of all the cheap ones that they carry.
ezab is offline
post #9 of 22 Old 11-27-2010, 12:51 PM
newfieZJ
I think I used a prestone on the 5.9 and a gatorback on the 5.2 . No issues since
newfieZJ is offline
post #10 of 22 Old 11-27-2010, 12:52 PM Thread Starter
andrayder
I just called around for a gatorback myself and no one here has them either
post #11 of 22 Old 11-27-2010, 01:03 PM
newfieZJ
If you want the gatorback , rockauto.com has them , what's few more days right .
Dayco's been around for a while , can't see it being too bad a product , Autozone carries them . Unless someone can say something bad about them ?
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #12 of 22 Old 11-27-2010, 04:42 PM Thread Starter
andrayder
Put a dayco on and the squeal is gone
post #13 of 22 Old 12-12-2010, 09:04 AM Thread Starter
andrayder
Sorry to bring this back from the dead but after another new belt after the dayco started squealing I put a gatorback on and the squeal has still come back! It seems a new belt temporarily stops the noises, but not for long. Any other ideas on this because it's driving me crazy.
post #14 of 22 Old 12-12-2010, 09:13 AM
melk
Tighten it more.
Start replacing pulleys.
melk is offline
post #15 of 22 Old 12-12-2010, 09:38 AM
mastercraft1988
Get a gatorback from Summit. It made all the difference with my 5.2 zj
mastercraft1988 is offline
Serpentine Belt Squealing Like A Stuck Pig? I Have A Story For You! STPer ZJ Grand Cherokee Forum 46 05-03-2015 10:57 AM
New S-Belt Squealing lambar ZJ Grand Cherokee Forum 7 03-03-2010 09:40 PM
Water Pump and Belt/Belt Tensioner pilitusf ZJ Grand Cherokee Forum 2 07-04-2009 05:01 AM
Squealing! Haleyrz ZJ Grand Cherokee Forum 21 12-31-2008 06:07 PM
AC squealing like mad motu1983 ZJ Grand Cherokee Forum 6 09-21-2007 01:02 PM
